Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: need help configuring a 4-way setup using xonar
    Mar 2009
    hello,
    i upgraded my carpc's soundcard to asus xonar deluxe hdav 1.3
    i'm having a problem routing the virtual audio cable stream back into console/audiomulch..
    do i need any special plugins for the VAC to show up as an ASIO input ?
    let me explain, so far i have configured winamp/foobar to play through virtual cable 1, then i opened up audio mulch and chose to use the ASIO driver of my xonar. i can't seem to figur out how do i set the VAC 1 as an input at the head of the tree..
    please help.
    FLAC WuNgUn's Avatar
    Sep 2007
    Your on the right track...
    You don't need anything special for VAC, BUT you must enable the input with ASIO (ASIO4All)...basically, it needs to be switched ON for it to show up as an input device...
    Make sure the 'power light' is on (you only need the input enabled)
    (BTW, this is with VAC not installed...for reference only!)
    Make sure you Reset Audio in Mulch after every change...
    Then the VAC input should be showing up in your input drop down list...
    (again, VAC isn't installed in this pic)
    Once VAC is setup as your only input device, your SoundIN contraption IS your VAC input...
    Notice you can have TWELVE seperate input devices! Make sure your in the SoundIN column if your using SoundIN as your line in...
    Mar 2009
    thanks man.. it really helped me alot.
    now, to the new problem --> the channels aren't seperated !! they mix into each other..
    i have noticed that you encountered the same problem. i switched to the newest drivers and i updated the firmware and still no go..
    again, help needed
    thanks
    Sep 2007
    Firmware? Hmmm...what changes did they make with the firmware?
    To eliminate the channel cross-talk, you need to use one of the Vista drivers...don't worry, they work in XP as well, except you'll loose the line-in/mic-in if I remember correctly (I use the onboard audio for this).
    I can't remember which version exactly...I THINK 1731. Try those and retest...
    Maximum Bitrate Crinos's Avatar
    Mar 2009
    Kristiansand, Norway
    Noob question... what good is a "Virtual Audio Cable" ?
    Is it something like "What U Hear" thing for SoundBlaster?
    So that you can have multiple sound inputs going out at the same time to the output/amp?
    In better words.. You can listen to MP3s/radio/CD's while the navigation voice is active ?
    Sep 2007
    It's a pass-thru audio device...instead of the music (or any audio) going to the sound card, it goes to VAC instead...
    Then your able to process the audio before sending it to the sound card.
    Mar 2009
    the problem remains..
    i tried many kinds of drivers and no luck..
    the only vista driver that could run on my xp machine is the oldest and its the 17.44
    i also tried diffrent kinds of xp drivers and still came up with nothing.
    (i removed the old drivers completly before i installed the new ones..)
    maybe its an xp problem ? will the problem go a way if i'll change to vista ?
    could you please check for the exact driver you installed.. did you install the driver completly with all the addons that comes with it ?
    thanks
    Sep 2007
    All the XP drivers will cross talk...I have no idea about the latest drivers though.
    The driver I'm using is the one dated 6/1/2007 in the device manager.
    Mar 2009
    as i said, i tryed all the drivers for the HDAV..
    should i try upgrading to vista ? does any of the asio problem occurs on vista ?
    Sep 2007
    HDAV drivers?? That's probably why your having a problem.
    You want the D2/PM drivers, not the HDAV drivers...I doubt there is much difference with them, if any...
    Try the 1731 RC01 version...
    The problem is with the drivers, not the OS...you'd get the same thing with Vista...
  1. pleasant experience with new setup
    By nst6563 in forum General Hardware Discussion
    Last Post: 04-28-2009, 08:22 PM
  2. What kind of setup do you have for a PCMCIA Card?
    By polo6979 in forum Wireless Communications
    Last Post: 04-18-2008, 12:36 AM
  3. Help with general setup
    By Blup in forum Newbie
    Last Post: 01-11-2008, 12:50 PM
  4. Centrafuse 1.2 won't leave setup
    By marchello2000 in forum CF Bug Reports
    Last Post: 07-03-2007, 12:18 PM
  5. Replies: 0
    Last Post: 03-20-2005, 02:34 PM
