Results 1 to 10 of 15
Thread: Looking for best USB sound w/ line in and SPDIF out
    Aug 2006
    Question Looking for best USB sound w/ line in and SPDIF out
    The onboard audio of my m/b can't send line in to spdif out so my radio does not work and can't use line in plugins.
    Now I'm looking for a really good (high end) "XP-Hibernation-safe" USB sound card w/ 1- line in and 1- optical (or coax TTL-level) digital out.
    Any ideas?
    //L
    Newbie Sponge's Avatar
    Apr 2009
    San Jose, CA
    Lightbulb
    Phew, thats a tricky one... I had a almost forgot about this guy:
    http://www.m-audio.com/products/en_us/Transit.html
    Will that work?
    Aug 2006
    That could work, but how is the S/Q of the digital out on this one?
    Apr 2009
    San Jose, CA
    Quantitative SQ is excellent according to this:
    http://www.learjeff.net/RMAA/results.html
    There is a ton of info about the Transit on this board... you may want to check up on the hiber-ability of the device.
    Jul 2006
    Brisbane, Australia
    Spent a bit of time looking at this myself. What about this one?
    Not much dearer than the Transit and is USB 2.0 not USB 1.1
    http://www.emu.com/products/product....&product=15186
    You got to read the specs carefully, but there are left and right inputs via 1/4" jacks.
    Does not seem to do optical but I don't need that.
    RodW
    2007 Toyota Hilux with a CarPC..
    Worklog: http://www.mp3car.com/vbulletin/work...ota-hilux.html
    OziExplorer GPS Embedded in RR: http://www.mp3car.com/vbulletin/sb-s...iexplorer.html
    May 2009
    Ladispoli, ROMA
    This are the most usb audio control used in carpc but are expensive
    http://www.terratec.net/en/products/..._USB_2084.html
    or
    http://www.gigasonic.com/motu,USB_Au...terfaces.shtml
    They are used to make all controll like internal routing, delay, elettronics crossover, with a Console program or others vsthost....
    Aug 2006
    Thanx for all the tips.
    I don't need DSP/x-over functions (have external DPS for that w/ coax and optical in).
    I need good quality digital out and line in that can be routed to digital out.
    The DMX 6Fire USB look great, I can use the XLR w/ 48v phantom to my RTA microphone and skip the behringer mixer board that I normally use for RTA.
    How about the TerraTec Aureon 5.1 USB MK II? All I need really but kind of sheep.
    Aug 2006
    I see now that the DMX min spec are 2ghz amd/intel, I have an atom 330 dual core system (1,66ghz), is that to weak?
    Apr 2009
    San Jose, CA
    I beleive those specs are for worst case, IE if you use all of those inputs/outputs. The atom should run it just fine.
    Keep in mind that some of these require a seperate power supply and some are USB bus powered.
    Youre dealing with digital to digital on reputable audio companies, the SQ should be perfect.
    Aug 2006
    I went from a PCI X-Fi ExtremeMusic (SPDIF) to onboard Realtek ALC662 (SPDIF) and the SQ is far worse, my only PCI slot is now occupied by a GFX so can't use PCI for sound
    So I don't think SQ on SPDIF is same for all vendors. I would prefer bit perfect SPDIF but not sure if that is achievable on all vendors cards.
    External power can be a problem in a car but its doable.
