Results 1 to 10 of 11
Thread: Amp dilema, any suggestions???
    Mar 2008
    Ok, so I decided to install a 4-channel amp that I had in my Jeep about 5 years ago. It is a 400W amp, and kinda cheap, but it worked, and pretty well. So I get it all hooked up, and WHAM! I get alternator whine. After regrounding the amp and making sure the power and RCA's were apart, I still get the whine. So I then check the RCA's... I switch the fron to rear and rear to front, still there... I then unplug one set of RCA's to see if it was the RCA, and WHAM! the noise was gone. But just to make sure, I use the other set of RCA's alone, and the noise was gone...
    So.. the short of it is that if I only have one set of RCA's connected, whether the front or back, but just ONE set, all is fine. once I connect the second set of RCA's, whether front or back, the whine comes back.
    I know enough about amps and such to be basic to pretty intermediate, but this has me stumped! I think I have a ground loop isolator laying around that I can try, but I'm not sure if that will help.
    And I know the amp is old, so it might be the amp. I am not opposed to dropping $100 or so on a new amp (yea, I know that's low, but I'm not out for a comp setup).
    So if anyone can shed some light on this for me, I would GREATLY appreciate it!!!
    Thanks!!!
    Ken
    Jan 2008
    Dartmouth, MA
    This sounds like it could definitely be a ground loop problem.
    Check out this page: http://en.wikipedia.org/wiki/Ground_loop_(electricity)
    Are you using tow cables which are EXACTLY the same?
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
    Vendor - Qube colin's Avatar
    Dec 2006
    Try grounding the two RCA grounds together, keep everything running at the same levels. It appears that inside your amp, the grounds are not the same or in your computer the grounds are not the same or your cables have largely differing resistances...
    Mar 2008
    Quote Originally Posted by PaulF View Post
    No. One RCA is from an amp kit, the other I bought separate, but they are both from the same company (Rockford Fosgate), bought the kit and cable from Best Buy.
    Thanks for the reply.
    Mar 2008
    Quote Originally Posted by colin View Post
    How do I ground the 2 RCA's together?
    Thanks!
    Jan 2008
    Dartmouth, MA
    I would say, try the system with two of the exact same RCA cable. The different lengths may be messing up the grounds. For testing purposes, use one of the rca cables you already have and connect ones of the wires to the red connector on one input, and one on the red connector of the other input. After, do the same for the white. If there is no noise in either of these setups, then it's the the cables.
    FLAC WuNgUn's Avatar
    Sep 2007
    Maybe one of the RCA chassis plugs on the amp isn't properly gounded...maybe it broke free with a WHAM!?
    But it sounds as if it's choosing the RCA's as a partial power ground when they are both connected...which means WHAM! Your power ground isn't good enough...Have you thought about doing the Big 3? It's something any car audio guy should do, and you never know, it could just as easily disappear, like WHAM!
    Maybe make your own RCA's as well...with a ground/drain connection only at the amp end?
    Mar 2008
    Quote Originally Posted by WuNgUn View Post
    WHAM!
    Thanks for the reply..
    It is a cheap amp anyway, so if the problem IS with the amp, then I will just go out and buy a real amp... I got it off eBay about 5-6 years ago or so.
    But what I did was put a Ground Loop Isolator on one of the RCA's and it seems to have fixed it.
    So for a semi-amature car audio guy, what is the Big 3? Sorry if I should know that, but I don't.
    Again, thanks for the reply!
    Ken
    Low Bitrate jake789's Avatar
    Apr 2009
    WHAM! This is one way to ground the rca's (usually needed in Pioneer HUs)
    Big 3:
    http://tinyurl.com/o4zcuw
    May 2009
    Hey guys, I need some help. I have three amps in my 2001 Cougar. Two power two sets of loud speakers and the third power my subs. I have bought a bass knob so I can put it on the loud speaker amps so I can turn them down. Having loud speakers always loud is a problem. But when I put the knob on the audio cables all three amps are put on the knob... Is there anyway I can have only the two amps on the knob and the third just on all the time? I have even ran two separate audio cables from the radio back to the amps but as soon as the knob is added it puts all three on it. Please help! :-(
  1. Replies: 94
    Last Post: 09-13-2011, 06:59 PM
  2. New amp is blowing fuses
    By melonzman in forum Car Audio
    Last Post: 06-15-2008, 05:24 PM
  3. Possible Bad Amp?
    By VetteC5RFrEak in forum Car Audio
    Last Post: 03-22-2008, 11:56 PM
  4. AMP wont turn ON!! HEELP!
    By pdjafari in forum Car Audio
    Last Post: 10-15-2005, 08:43 PM
  5. 5 channel Amp suggestions
    By biglips31 in forum Car Audio
    Last Post: 11-05-2004, 04:30 PM
