i hope this isn't too far from the general topics discussed in this forum.
i had a CD label stuck in my 2004 Toyota Corolla factory CD player, so i took the stereo out (using instructions i found on here!) and removed the offending label. after reinstalling the stereo, it won't turn on. i assume that this is an anti-theft precaution, but i can't find the reset button/switch/code/technique in the owner's manual. i would rather avoid a trip to the dealer.
anyone have any suggestions?
thanks!
I believe for this model corolla, if the radio has the security feature the screen will say "SEC" until the proper code is typed in.
Make sure you check all the radio fuses with a volt meter or test light. Specificaly, check the dome light fuse and cigarette lighter fuse as those power the radio.
Here is the radio wiring diagram for a 2004 Toyota Corolla:
2004-Toyota-Corolla-Radio.PDF
You can use those wire colors or pin numbers to make sure you have power at the appropriate pins in the radio harness connector.
Good Luck.
** Denotes an "in car" post
In-Car posts made from passenger seat - Be safe, Don't Post and Drive.
thanks for the suggestions! i'm not really sure what fixed i... i finally got back to looking at it today, and the first thing i did was make sure the power connections were snapped in to place. then, i took the whole thing out again and reconnected everything, and it worked... it might have been the ribbon cable between the faceplate and the stereo, because when i removed the faceplate (for no good reason) the ribbon cable fell out of the socket. perhaps i loosened it enough the first time that it wasn't making good contact even though it wasn't until this time that it actually fell out.
in any case, thanks and no need to worry about anti-theft measures on this stereo!
