Results 1 to 4 of 4
Thread: Ipod to 5 channel amp, no head unit??
    May 2009
    Question Ipod to 5 channel amp, no head unit??
    Hello,
    I'm planning a system for a Polaris RZR side by side UTV. The sytem will consist of an Alpine PDX-5M amp, 2-6.5 component speakers, 2-6.5 coaxial speakers, and a 10" sub. I will be using an Ipod fed to the amp via a JL Audio CL-RLC 2 channel remote level line driver. My main question is, how do I take the 2 RCA's coming from the CL-RLC and split them to feed a 5 channel amp? Is this possible? I know there are Y splitters available, but are there any out there that turns 2 RCA's into 6? Help would be greatly appreciated!
    Russ
    Elsewhere
    You need something that will take the simple stereo from the iPod and split it into 4 channels + sub for the amp.
    Many equalizers do just this. I use an AudioControl Three.1 which is a great unit for the audio from my PC. It's pricey, but a damn fine unit.
    There are other makes/models out there that can do the same thing.
    How about the Wiki?
    Maximum Bitrate Crinos's Avatar
    Mar 2009
    Kristiansand, Norway
    You would allso like to have a crossfilter of sorts... Either in the amp or before inside your splitter. (for letting the sub play the deep sounds, and not everything you put into it).
    Jan 2008
    I am currently using a clarion 3 way active crossover. this allows for 2 inputs, and has 6 outputs, 2 high pass, and one low pass, all at 18 db/oct (much better filtering than most low/mid grade amps).
    this is one of the better units that i have found for under $200. if you are interested in something above $200, audio control and alpine both make some great audio processors, that should also accept a stereo input and convert it to 5-6 channels.
    http://www.sonicelectronix.com/item_...n+MCD-360.html
  1. Replies: 5
    Last Post: 12-05-2009, 08:03 AM
  2. car audio amp stock head unit
    By thebeebster in forum Newbie
    Last Post: 06-26-2006, 10:26 PM
  3. CD head unit remote amp turn-on - Can it be used to trigger standby?
    By mach5 in forum General Hardware Discussion
    Last Post: 06-18-2006, 05:45 PM
