Page 1 of 4 1234 LastLast
Results 1 to 10 of 37
Thread: Does size matter on a SUB?
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    I'm slowly starting to get my Car PC done, but have a few questions. Basically on my rear of the truck I am adding 3 AMPS. Two of them will go to the right side and be tucked under my Car PC case. Now because of this I have lost a bit of space because the PC case and amps stick out a bit. I can afford to take up more room, otherwise my 4 dogs can not fit into the car. If I get a 12 inch sub, it will be way to big because of the magnet. If I get the 10 inch the magnet is smaller. The Sub I want tis the Alpine R-Series AMP. Both the 10 and 12 inch seem to use the same power 500 RMS, 1500 Peak.... I was wondering, will I notice the difference in sound? Will 2 inches really make a difference? Also a sub and AMP can be placed together? I am thinking maybe I can build it so I can take out the sub box when the pups are in the car, but the smaller the better for me.
    Also can an amp be sitting on its side? Rather then Horizontal, Vertical?
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
    Newbie bigdakota98's Avatar
    Jun 2008
    You can mount an amp on it side or upside down it does'nt matter. Just make sure it can get air to keep it cool. The diffrence between a 10" sub & 12" sub is the type of bass responce. The 12" will be deeper and boomier than a 10". It really depends on you music type.
    Vendor - Qube colin's Avatar
    Dec 2006
    Basically, yes, you can hear a difference. If you don't buy the 12" in the first place, you'll never know what you're missing and it won't bother you. Its not like it sounds worse, it's just less of a BOOM than a larger sub.
    Jul 2007
    Miami
    Only thing I notice is frequency..... The 10' is 24 -600 Hz, the 12' is 23 - 600Hz. What would be the best sub for movies and music. I may just get the 12', if its too big I will make a quick disconnect system so I can just pull the amp and sub out.
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    Jun 2008
    Quote Originally Posted by HiJackZX1 View Post
    I have a 12" sub in my dakota and it was awsome while watching movies.
    May 2009
    You don't want sub and amp inside of sealed box. Heat issues.
    Look into shallow mount subs, you can make a large flat box with them.
    Movies? Go with 12".
    If you prefer quality over quantity: Peerless 830877 12" XXLS Autosound Subwoofer
    I got two 10" Alpine Rs, switching to 12". Never enough bass. You just need to deaden the car, otherwise everything will rattle, and the bass is no longer clear.
    Jul 2007
    Miami
    Quote Originally Posted by digital79 View Post
    I really had my heart set on the Alpine R-Series sub though, since all the other speakers will be Alpine also. I don't want to mix and match. I don't want bass thats going to get me heard 3 blocks away. Just something to compliment the movies. The AMP I am using is only 500 RMS
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    Maximum Bitrate Injector's Avatar
    Mar 2005
    Rockledge, FL
    well think what sound is, sound is the vibration of air, that's why kicker started making squared subs because a square has more area than a circle, so in theory it should be louder, but as you said when you increase the size you also change the frequency.
    Low Bitrate jake789's Avatar
    Apr 2009
    Type R subs should only be in a ported box. I've only heard bad results when people have tried sealed.
    Also from most reviews, the type R is a loud and boomy sub, even in the right box it probably wouldn't be the best choice for movies.
    May 2009
    It's OK to mix sub brands with your other speakers.
    Single 12" sealed should do fine.
    However, if you are really concerned about the space, and can afford an extra driver, go for iso-barik box. It's more complex to build, less loud, and some subs are no good for it, but it cuts box size in half. Read more here.
  1. HELP! Please post your LCD Panel Size and model info
    By Splash-X in forum LCD/Display
    Last Post: 01-24-2008, 08:23 AM
  2. MCI error 261 and 263
    By genesis66 in forum Road Runner
    Last Post: 12-21-2007, 02:59 PM
  3. Replies: 21
    Last Post: 11-13-2006, 07:35 AM
  4. Music text size
    By Pokey in forum MediaCar
    Last Post: 06-15-2004, 08:00 AM
  5. changing font size of file names in Windows Explorer?
    By Squeezer in forum General Hardware Discussion
    Last Post: 01-11-2001, 05:49 PM
