+ Reply to Thread
Results 1 to 2 of 2
Thread: Problem with SPL amp in protected mode
    Jun 2009
    Unhappy Problem with SPL amp in protected mode
    I recently hooked up an SPL 1800 watt 2ohm stable amp. I just hooked it up to 2 Memphis M3 Dual 2ohm VC subs. I hooked it up and ran them in series. The amp was pushing them great and it sounded perfect. On my way to work today everything just quit, i stopped to look at it and my amp was in protected mode. Everything to the amp is hooked up fine, no blown fuses, no wires crossed, I'm clueless.
    Constant Bitrate thewizard's Avatar
    Dec 2008
    You would have to wire these subs in a series parallel configuration for this amp to remain stable. Wire two of the voice coils in series (one voice coil from each sub, then repeat the same with the remaining two voice coils) then connect both of the two series circuits in parallel at the amp. This will allow your amp to see a 2ohm final load. When connecting your series circuits be sure to connect + to - between the two coils so you end up having a positive and negative remaining for your amplifier connection.
+ Reply to Thread
  1. Only problem left..... BMW E36 Amp.
    By Hellmet in forum Newbie
    Last Post: 04-20-2008, 09:49 AM
  2. AMP Popping, Hissing, Shutting off...PLZ help?!
    By Dougw133 in forum Car Audio
    Last Post: 12-10-2007, 09:24 AM
  3. 2 to 1 amp problem
    By lexdiamond20 in forum Car Audio
    Last Post: 07-02-2007, 04:50 PM
  4. Mustang amp problem
    By Troteck in forum Car Audio
    Last Post: 05-14-2006, 11:58 PM
  5. bizzare amp problem
    By vangore in forum Car Audio
    Last Post: 03-09-2006, 09:58 AM
Tags for this Thread
