Results 1 to 7 of 7
Thread: Car stereo without head unit
    Jun 2009
    I'm looking to install a stereo in my Camaro.. it currently has no speakers or a cd player. Is it possible to just run an amp to a couple speakers and use an iPod as my cd player? Would i need an amp with an aux input? if so are these common?
    Thanks!
    Jan 2008
    Quote Originally Posted by 81Z28 View Post
    Thanks!
    I am kind of confused what you are asking--- do you want a cd player and ipod connectivity, or just to use your ipod as the source?
    if you want to use your ipod as the source, it is entirly possible:
    currently, I am using my ipod as the source while i work on my car computer-- all that is required is a 1/8" stereo to rca cable that runs to the amp, and to hook the amp up to a switch to turn it off when your not in your car.
    Newbie Sponge's Avatar
    Apr 2009
    San Jose, CA
    Soundman's advice will work very well. I do the same when my computer is down.
    Just annother option taken from this thread: No head unit -- Ipod ONLY audio system...ideas???
    iPod->LOD cable->Volume knob->Amp RCA inputs
    Maximum Bitrate Crinos's Avatar
    Mar 2009
    Kristiansand, Norway
    You would need to tell the amp to turn on.. In other words, give it the 12v power-on (wake-up) signal.
    This can be done many ways... either by flipping a 12v switch, or use relays and connected to ignition, so that the amp will go on when the car is running and stay on.
    Nov 2006
    This might be a stupid statement (please correct me if it is) but, rather than rigging a switch or relays, could you not just wire the amp as normal and just use the 12V accessory line to the amp turn on terminal as a means to turn the amp on when the system is switched on. Is this not what the amp turn-on wire from head units do?
    Elsewhere
    Quote Originally Posted by smyles View Post
    You are 100% correct.
    How about the Wiki?
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Use a switch plus ign/acc just as a precaution. ACC->switch->Amp remote. This way it will always be off with the key off in case you forget so you don't drain the battery, and use the switch when the key is on and you want to plug in the ipod (or turn it on, etc.) so you don't pop the speakers.
  1. Replies: 6
    Last Post: 05-11-2007, 01:39 AM
  2. Seat Ibiza Mk4 Alana Head Unit - need sound in!
    By onlineamiga in forum General Hardware Discussion
    Last Post: 02-11-2007, 06:02 AM
  3. Taking internal amp out of head unit.
    By stonestatue in forum Car Audio
    Last Post: 01-19-2007, 02:28 PM
  4. XM-Ready head unit software integration?
    By TaZMaNiaK in forum Software & Software Development
    Last Post: 04-02-2005, 06:23 PM
  5. New Sony head unit - botched wiring...
    By SamDude in forum Car Audio
    Last Post: 09-09-2004, 05:21 PM
