Welcome Mike, yes, you are on the right track.
A 1000w amp and a pair of ported L7s can get pretty damn loud. I would recommend trying the set up with one amp first before you go spending a few hundred more on another amp... that you might not even need!
However, that poses a problem... if you choose to use a single amp you would want the dual 2ohm version and if you decide to run two amps, you would be better off with the dual 4ohm version. Read this to get a better understanding: http://mobile.jlaudio.com/support_pages.php?page_id=161. This is all in an effort to present a 2ohm load to your amp.
$650 is a large budget for subs, you can find some pretty nice equipment in that price range so shop around a bit more, talk to some people, listen to some systems and hop on some car audio forums. FYI: Kicker L7s and a box can be found on craigslist for pretty cheap.
Now go build a CarPC!![]()
LinkBack URL
About LinkBacks
