Results 1 to 2 of 2
Thread: Help wiring into stock amp wiring harness
    Newbie armysgt's Avatar
    May 2009
    I have a soundblaster live 5.1 card I need to hook up to my car's stock infinity amp wiring harness. The harness is the only input/output on the amp. I need to wire two stereo cables into it.One for the front speakers, one for the rears. I have the sub taken care of. How do i splice these stereo cable into the harness. I know what colors the wires are and everything, I have the speaker wiring diagram. Any help would be appreciated, I'm tearing my hair out.
    Electronic Space Foot
    Jan 2008
    Being that you already know what colors are what, you will just need to make sure that the amp accepts a low level input, instead of a high level, if it takes a high level, none of this will work. If it does accept a low level input, then cut the headphone cable there should be 2 wires a shield. the wires are the left/rightpair, and the shield is ground. the ground will need to be wired to both negative speaker leads, and the left / right should be to the positive leads. wire colors change between manufacturers, so it would be best to check which is which before hard wiring anything.
  1. 2007 Ford Fusion Carputer (version 2.0)
    By FusionFanatic in forum Show off your project
    Last Post: 04-20-2009, 05:56 PM
  2. Wiring up an amp
    By Leonfoster in forum Newbie
    Last Post: 10-10-2008, 04:05 PM
  3. Wiring CarPC from Amp wiring?
    By Calipso in forum Newbie
    Last Post: 02-03-2007, 06:32 PM
  4. Need some help with sending audio to stock amp
    By orangewhip in forum General Hardware Discussion
    Last Post: 09-04-2003, 02:21 PM
