+ Reply to Thread
Page 1 of 4 1234 LastLast
Results 1 to 10 of 38
Thread: Physical Volume Control
    Jun 2008
    Ive searched several threads on this forums and I'm not really finding much that seems like a good option. I need something that is a physical volume knob that I can mold into my dash for control of my volume instead of having to look at the screen and find the button and keep pushing it to make my volume go down. I realize I could do something with fusion but thats not what I want. I need something I can use right away.(The griffin powermate is not an option because its way to big to put into the screen)
    Nov 2006
    One of these should do the trick:
    http://www.sonicelectronix.com/item_...+Control-.html
    May 2009
    Or one of these if you like USB:
    Powermate
    Variable Bitrate csfile's Avatar
    Feb 2009
    Quote Originally Posted by mdawg View Post
    Quote Originally Posted by joshuo View Post
    Powermate
    OP: How much space do you have to work with?
    Feb 2009
    Just searched a bit around here because I remembered people hacking up a mouse to make a knob and using volumouse:
    $10 volume knob fabbed
    You can fab up a knob any size you want
    May 2009
    Quote Originally Posted by csfile View Post
    Uuuuuhhhh
    Sep 2008
    Western Australia
    I'm in the same situation. I figure it will be better to have the volume knob control the amplifier input rather than the software output in case of glitches/etc. Also my carputer is in the boot so if I got one of these: http://www.sonicelectronix.com/item_...+Control-.html I'd have to run RCA to the front, right?
    Instead I've found this: http://mobile.jlaudio.com/products_c...hp?prod_id=446 which looks like you only need to run the wires for the knob to the front. Plus the pass-through seems handy. Does anyone know of a similar but less expensive alternative?
    Jun 2009
    Melbourne, Australia
    switch that cuts the remote send line to the amps would do the trick :P
    but seriously it would be handy if the reason your doing this is say a phone call, or you need to speak to someone.
    otherwise you could invest in making or buying for that matter a pre-amp like most higher enough home theater systems have, and just havfe the pre amp mounted in the front, like second din slot or glovebox
    Jun 2008
    The knob needs to be really small. I have a Alpine MRP-F450 amp, there is an extra connector on the amp itself is that for volume control?
    Jun 2008
    Quote Originally Posted by zillacles View Post
    I like the idea of the first thing you posted assuming it doesn't kill the sound quality
+ Reply to Thread
  1. Volume control on PC or headunit?
    By efun in forum Car Audio
    Last Post: 01-15-2009, 10:48 PM
  2. Volume Control?
    By Teebs in forum Road Runner
    Last Post: 12-12-2008, 03:57 PM
  3. Replies: 0
    Last Post: 12-01-2008, 05:48 PM
  4. Soarer Volume Control
    By Beezer in forum Hardware Development
    Last Post: 04-28-2007, 12:25 PM
  5. Change behaviour Volume control
    By DbXL in forum Centrafuse
    Last Post: 07-09-2006, 12:09 PM
