a sound card is not nessesary, but the quality difference would be worth it for the setup that you are planning. I believe that both of the items that you linked to should work fine.
the case that you linked to might be an issue if you choose to run a sound card. the mother board does have a pci port, so any pci sound card will work.
LinkBack URL
About LinkBacks
