That link takes you to a login page.
Do you think thiswith two femelles rca will have good quality for an sq ssystem ?
or do you have another thing like this whop will have verry good sound quality...i want i very clean signal.
i alrealdy have my rcas installed
My Nearly Complete Car:
http://www.mp3car.com/vbulletin/show...ed-car-pc.html
Micro Control Center... Control Your Car Across the Internet
http://www.mp3car.com/fusion-brain/1...-internet.html
Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
http://paulfurtado.com/
I'm sure the sound quality you will get out of that device will be fine. But without the actual specifications of it, I can't give you a real answer.
Those adapters are cheap enough that you can buy a few different ones and try them out to see which sounds best to you. Usually I go to radio shack for things like that.
Don't think it would affect the sound as long as its not too cheap.
I would pick this style personally
http://www.monoprice.com/products/pr...seq=1&format=2
There's no cable runs so you shouldnt notice any difference in the quality. Should be okay.
2001 Mustang Convertible Worklog
Indigo Custom Frontend (Flash/Delphi)
Blog
Qube v1.3 Now Available at the mp3Car Store!!!!!!
The simplest IO controller you'll ever use!
Copper is copper, unless the adaptor you buy is so cheap that it's faulty out of the box, then you won't hear any difference.
I would recommend using a cabled jack to 2x RCA cable, as this won't put excess weight on the flimsy 3.5mm jack, whereas the above adaptor will, and thus, can shorten the life of the jack socket in whatever it is connecting to.
let's put it this way:
Your not going to notice any difference in quality if you used platinum contacts or copper contacts. Your in a car there will be plenty things masking the quality of the sound!
