The amp can be 450watt at max with a 30A fuse, based on 15v current.
This would be true if you had a class-d amp... well.. kinda true.. the best amps can give you as much as 98% effect.
For a normal class-b amp, you would have something like 300watt
the "blaster" is probably 1000w PEAK...
But, to answer your question...
It looks like your overpowering the amp, so that it goes hot, and shutsdown. Even thought the casing of the amp is not hot enough to burn you, the components can be to hot... especially if they are of the cheaper type.
Whey buying an amp, "getting what you pay for" is a true statement..
