Page 1 of 4 1234 LastLast
Results 1 to 10 of 32
Thread: Amp protect light on :(
    May 2009
    England
    Exclamation Amp protect light on :(
    When I'm driving, at random my music will just stop. I pull over look at the amp, and the red protect light is on instead of the green power light.
    At the moment I have my carputer outputting into the 2 RCA inputs. The computer and amp are both grounded to the same place.
    I only started happening when I replaced the stock HU with the computer.
    What is the cause. Is it yet another dodgy grounding or something else?
    I also have a sub, 2 6x9's and 2 5.25" speakers powered from it.
    JM
    thekl0wn's Avatar
    Apr 2005
    PoCo, Indiana
    Is it a 5/6-channel amp? If not, you've probably got some serious issues going on with that end of the wiring!
    A bad ground can cause this. Overheating can cause this. Something broke in the amp can cause this. Clipping can cause this. etc.
    Play with it, 'til it's broke.
    May 2009
    England
    it's a 4 channel 1000W amp. When I felt it, it did feel quite hot :S.
    Are there any troubleshooting methods u guys have?
    thekl0wn's Avatar
    Apr 2005
    PoCo, Indiana
    How in the heck is that thing wired?
    And what kind of amp is it? Almost any amp is going to get hot. It's just a matter of how hot.
    May 2009
    England
    I have a blaster bl-1000 amp.
    I have the amp plugged into battery through 30A fuse. Sub bridged with 2X250W ports. The 6X9's and 5.25"s are plugged into remaining 2 250W ports.
    PC is plugged into battery and ground is in amp ground port (also grounded to chasis).
    The amp turns on via PC remote (m4-atx).
    Anymore info needed please state
    JM
    Jan 2008
    are the 6x9's and 5-1/4's wired in series or parallel, and what is the end load on the amp(measured across the output terminals of the amp)?
    also, what type of subwoofer(brand, model #) and how is it wired if it has more than one voice coil? and again, what is the end load on the amp?
    how hot did the amp get? most amps, when they get hot enough to go into protect will be hot enough to burn you.
    I did a very brief search(very brief) and did not see anything about the amp being 2 ohm stable, so i have a hunch that you will find that either the end load is 2 ohms(for either the sub or speakers) or that you have a grounding issue.
    May 2009
    England
    The 6x9's and 5.25" speakers are in parallel.
    Amp speaker ports (250W) each.
    1) One Kenwood KFC-M6942A speaker and Kenwood KFC-1350S speaker both in parallel.
    2) One Kenwood KFC-M6942A speaker and Kenwood KFC-1350S speaker both in parallel.
    3 + 4) Bridged kfc-w3011
    The amp was definately not hot enough to burn me, so I guess that's out of the picture.
    How do I measure the end load?
    JM
    May 2009
    England
    o and before I replaced the HU for the computer, I had all speakers except the 2 - 5.25" speakers plugged into the amp all running fine.
    Jan 2008
    to measure the end load, unplug the speakers from the amp, and put a ohm meter across the 2 connections.
    Quote Originally Posted by jellymonster View Post
    I think that this is where the problem is-- having 2 speakers parallel for each channel will produce a 2 ohm load. try hooking the speakers up in series. this should produce a 8 ohm load, but will be alot quieter, and will not send the amp into protect.
    May 2009
    England
    ok, I will give that a go. At the moment I'm sorting out yet another problem, hopefully I will get a chance to test it tonight .
    Thanks for your help.
  1. Replies: 38
    Last Post: 11-30-2010, 06:04 AM
  2. Unusual amp shut off problem....please help!
    By mike40370 in forum Car Audio
    Last Post: 12-05-2007, 05:13 PM
  3. Amp running hot...??
    By Emerica2843 in forum General Hardware Discussion
    Last Post: 02-08-2006, 06:40 PM
  4. Amp running hot...??
    By Emerica2843 in forum Car Audio
    Last Post: 01-29-2006, 08:29 PM
Tags for this Thread
