The other day my mate and I were in my car listening to music when he thought that one side of my car was louder than the other. So we listened to each speaker and sure enough, one side is louder.
I then unplugged the 3.5mm jack from the PC and tested it with earphones. It was clear that the left earphone was extrememly quiet and the right side was normal.
Not really sure on what to do :S.
I am outputting music from the integrated sound card on the GA-8S661fXM-775 motherboard :http://www.gigabyte.com.tw/Products/...ProductID=1842
Is it dodgy driver or something simple like that? or is it more serious?
JM
Ok, I will try these. I'll go get my PC out the car and set it up in my house (be easier :P)
thanks for the replies
sorry, didn't look at the OP, it could have some thing to do with your amp settings(in the other topic you posted), so before you go too far, repair that problem first.
but that doen't explain why the earphones do the same thing :S
/retracts previous post/
windows is set to desktop stereo speakers. I also tried stereo headphones still with no luck.
I updated to the latest sound driver, no change.
Balance is in the middle, if I move it left it goes quite only playing from left side. If I move it right it's loud and only playing from right side.
thanks for help, keep the ideas coming
JM
Under the speaker driver software, there are option to make the input jack and mic jack into speaker outputs. I never got this to work with the older version I had, I don't know if I'll have more luck with the latest version. But atm I have one output, which is split into 2 to go into the amps to inputs. Will it work if I try and make another output?
