Results 1 to 2 of 2
Thread: Sony xplod HU over heating?
    Jul 2009
    So my buddy helped me for a bit yesterday to get the CD player (sony Xplod) hooked up in my boat....but now the back of it gets pretty damn hot (hot enough to burn me if I touched it..... Options:
    1) the old am/fm radio that was in there had a much smaller fuse so maybe its getting hot because of that...
    Fix: replace fuse with bigger fuse
    2) the old radio didn't need a as much power so the new radio is trying to pull to much power from the helm.
    Fix: run power back from the battery
    3)the old radio had all seperate "possitive" wires fo the four speakers but the left and right side speakers shared a "negative" wire.... on the new radio this might be creating to many ohms and causing to much resistence causeing it to heat up.
    Fix: run seperate "negatives" for each speaker
    4) a few people said that the back of the radios do get hot and not to worry about it, espesially the sony's. (however it burn me when I touched it so im thinkng that maybe its too hot.)
    Any ideas?
    Jan 2008
    with newer radios, they are more sensitive to the way they are hooked up-- you will need to run separate + and - wires to each individul speaker, this should cure the heat issue.
