+ Reply to Thread
Results 1 to 10 of 12
Thread: Alternator Longevity
    Jul 2007
    Indianapolis, IN
    I just found out my alternator is trashed on my 2005 Ford Explorer.
    I bought a new Yellow Top and am getting the alternator replaced. I have an extended warranty that will only cover the OEM alt.
    My questions is: Do you think I will trash the new alternator given it is probably the same specs as the one that burned now?
    Did my system kill the OEM prematurely? I have 2 Alpine amps... A 4 channel and 2 channel (pushing 2 10" Alpine subs) plus my car pc.
    And, if I have to have an OEM alt, is there something else I can do to supplement power so I don't kill it too?
    Thanks!
    My System (2005 Ford Explorer)
    VIA EPIA MII 12000 Mini-ITX Mainboard
    1 GB RAM
    80 GB hdd
    250 GB USB hdd
    M2-ATX
    Storex USB DVD Rom/CDRW (not yet installed)
    D-Link DWL-121 WiFi
    OBDII Elm327 v1.2a (not yet installed)
    Lilliput EBY701-NP/C/T
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Depends on how many amps you are drawing. If you are drawing a significant amount of the capacity that the alternator is able to provide, yes, you could shorten it's life.
    How many amps is your alternator? How many amps does your system(s) require?
    The only option would be to get an aftermarket alternator that is bigger. Capacitors and bigger batteries don't solve this problem.
    Want to:
    Constant Bitrate thewizard's Avatar
    Dec 2008
    Quote Originally Posted by Bugbyte View Post
    I'll second that statement. Capacitors will do nothing to help an electrically underpowered system. It was thought for many years that a cap would help to cushion heavy quick draws of amperage, but it has been proven that this statement is in fact false. Alma Gates removed all of the capacitors from her record holding SPL Bronco because she discovered that her SPL was actually higher without them in the system and that they were nothing more than another load on the system. The only benefit to a cap in a car audio system is that it helps to filter out some A/C ripple and in effect some noise, but in reality any cap more than 1 or 2 farad is completely pointless, except for maybe some show "bling".
    Variable Bitrate 84RegalRider's Avatar
    Nov 2004
    San Diego
    eh you aint pulling that much i would say.
    trashed? as in how?
    rebuilding them is eazy most of the time.
    But i havent killed mine yet and i have 2 batts, 2 amps, and a carputer.
    Gen4/5 (which ever you have) alts are usually pretty good.
    Core duo
    1tb harddrive
    256 ddr
    8 lilliput
    bu-353
    still installing...
    Jul 2007
    Indianapolis, IN
    So I've made some phone calls to local car audio install shops that tell me I should be OK w/ the yellow top and a new stock alternator. Autozone had one w/ a lifetime warranty (130 amps) so I figure if I toast it again I can get it replaced for free... Hopefully.
    I wonder how I can tell EXACTLY how much my system pushes/requires and how much my Explorer requires?
    Or better yet, how can I monitor the alternator so I know if it is struggling to keep up?
    1 GB RAM
    80 GB hdd
    250 GB USB hdd
    M2-ATX
    D-Link DWL-121 WiFi
    May 2009
    ^ isn't that possible through OBD2?
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    You can monitor the voltage that your OBD2 port sees via an ELM command (I forget it, look it up on google), however if you have a USB ELM devices chances are the voltage command will always return 12v regardless because the elm in most usb devices is powered off an internal regulator.
    You could get a fusion brain, but it only accepts 0-5v input and it's not protected in any way so I wouldn't suggest hooking up your car's voltage to it without some supporting circuitry. If you get that protection that could do it. You could even work in an amp-meter
    Quote Originally Posted by mitchjs
    stop with the REINSTALLS, what do you think we got some lame-o installer!!!
    RevFE - Super fast, modular frontend. Most powerful skinning engine in existence. Strong enough for an i7 made for a fitpc.
    Just a shame I can't justify a carpc to use it on anymore.
    Jul 2009
    MinneSNOWta
    Stock alternators are not rated for continuous duty. In other words a stock type 140 amp alternator can only output full power for a short period of time. this is how they are designed and. that is a maximum rating at a certain rpm etc. If you are pulling a lot of power from the battery to the point where the alternator is having to work hard for long periods of time. then can overheat. they can also go into saturation where they simply go wide open and the voltage go up to 16volts. then they cook the battery and you start an endless cycle of replacing batteries and alternators. stock alternators just weren't designed with big big car stereo systems, where you have a large constant current draw, in mind. they were designed for the short large current draws like from a starter motor and a smaller constant current draw over time.
    Heavy duty purpose built alternators are a different story. I have seen specialty alternators built for the car stereo market that will output full power all day, again as long as it is held at a certain RPM.
    The Optima batteries while cool, and can be mounted in any position etc. have one major downfall not many people understand. They typically have a lower A/Hr rating per a given size then a conventional lead acid type battery. What this means is. that with a given fixed load, the optima battery will die faster. everyone talks about CCA, cold cranking amps, but that spec is meaningless when it comes to car stereo's. CCA is simply the measure by which how many amps maximum can be drawn from the battery for a very short period of time at 0 degrees. The A/hr rating which is often not published is the amount of current that can be drawn from the battery per hour for a given period of time.
    there is just no substitute for size. Great big die hards have a very long A/hr rating. and in a car audio system will last much longer and your alternator will not have to work quite as hard. as the alternator can recharge the battery at a lower rate over a longer period of time. where as optima batteries of any color have a very short A/hr rating for the same group size. this means your alternator has to work harder to keep that battery charged! adding another optima would give you a longer A/hr rating and again your alternator would have an easier job.
    as long as you dont run the batteries all the way down. IE less then 11 volts. in which case a proper wall type battery charger can bring the battery up to a level where the car's alternator can handle it without burning up.
    Jul 2007
    Indianapolis, IN
    Quote Originally Posted by mroverkill View Post
    OK, so are you saying I'd be better off w/ a larger Die Hard than the Yellow Top if I'm using a stock alternator?
    1 GB RAM
    80 GB hdd
    250 GB USB hdd
    M2-ATX
    D-Link DWL-121 WiFi
    Jan 2008
    Quote Originally Posted by develguy View Post
    no, he is saying that for a large stereo, a large diehard sealed battery and a high output alternator would be best.
+ Reply to Thread
