Results 1 to 4 of 4
Thread: Wiring Help: rear Zone Headphone Cutoff
    Newbie meep's Avatar
    Jul 2009
    Hi All
    First post - be gentle. I searched for an answer to this but had no luck.
    In anticipation of Centrafuse (or some other) sytem offering multi-zone capabilities, I'm designing my CapPC and amplification to include discrete rear and forward zones.
    Using a multi-channel external sound card, I hope to feed a pair of two channel amps powering front and rear speakers. Through software, I can feed the same signal to each zone or different signals to front and rear.
    I want to place a pair of headphone jacks in the rear. Normally, the rear zone audio is directed to the rear speakers. However, when one or both headphone jacks are in use, audio should go there and xut off from rear speakers.
    Anyone got pointers to a wiring diagram to effect this? PC soundcard outputs will likely be phono style.
    Thanks in advance
    Peter
    Jun 2005
    chicago, Illinois
    Check this out: Click Me
    It's a stereo jack that permits the transmission of the signal to pass through it when no plug is inserted, and interrupts it from passing through when the when the plug is in and feeds the signals to the plug. I think that is what you are looking for and easier than complicated wiring.
    I believe that this should be wired in between the RCA lines before it goes to the amp, because the headphones will not be able to take high amplification.
    PROGRESS:
    Jul 2009
    Thanks pancit175
    Will line level phono outs from a sound card be enough to drive a pair of headphones or will I need a small headphone amp? Or better with resistors inline from power amp?
    Peter
    Jun 2005
    chicago, Illinois
    I would assume so, but it's easy to just check it out. Just plug in a pair of headphones and go through the various volume levels.
    If it does require an amp you may need a different type of plug that has a SPST relay integrated and more complex wiring.
    PROGRESS:
  1. [CoupeE46] BMW E46 2001 330ci CarPC ...
    By CoupeE46 in forum Worklogs
    Last Post: 10-02-2008, 07:16 AM
  2. wiring a rear view camera - help please
    By apriti00 in forum General Hardware Discussion
    Last Post: 06-09-2008, 03:48 AM
  3. Wiring question...
    By atikali2000 in forum Newbie
    Last Post: 04-17-2008, 10:21 PM
  4. if you designed a vehicle's interior and wiring, how would you do it?
    By stapan in forum General MP3Car Discussion
    Last Post: 12-26-2005, 01:56 PM
  5. Specific wiring schematic 4 Optrex DMC40457?
    By sooty in forum LCD/Display
    Last Post: 07-17-2001, 02:11 AM
