Results 1 to 10 of 19
Thread: carputer to car speakers
    Low Bitrate ph7ryan's Avatar
    Dec 2008
    Atlanta
    I have taken on the nobel task of building a carputer, but since I will be using it in place of a radio unit, I will need a way of hooking it to my premium audio system (4 speakers + 2 tweeters) and my sub....logical thing to do would be to buy a pci card with 6 channel audio....Too bad no mini-itx cases are tall enough to fit pci cards properly so my life just turned to hell....
    Next best choice is a usb audio solution...http://www.amazon.com/Channel-Extern.../dp/B000XXY5Q4 maybe???? Would this be enough alone to power the speakers as loud as a normal oem radio unit would...if not how loud would it get...
    I would like to either use no amp, and just have lines from the computer audio to the speakers, OR I want a CHEAP ($20 or less) preamp output so that I could run it into a small amp...
    I basically want to have it loud enough to compare to a normal car radio loudness....
    Thanks for any help...
    Dec 2008
    youre goinjg to need an amp... you made that decision when you eliminated your deck (amp).
    Mar 2006
    Colorado, but Canadian!
    just use your soundcard and put it through an amp. I bought my amp for $19.99 free shipping and has been going strong since early 2006 with between 2 to 6 hours usage each day (delivery driver).
    It doesnt sound great, but it sounds just like my old HU did, and honestly they are going through stock speakers anyways so I dont really care. With winamp at 50%, wave output at about 10% to 15%, and master output around 10% it is loud. I control my master volume only, all the rest of the settings stay the same. Loudest I go before I would kill myself with a headache would be 25% and that was going down the interstate at 80mph+ with all the windows down and the sunroof fully open.
    Can't be beat for less than $20...
    1.9in x 2.9in -- 47mm x 73mm
    Dec 2008
    Atlanta
    ok...I have the onboard 2 channel audio...and you are saying just split the left signal to 2 and the right signal to 2, feed the wires to the amp and have the output of the amp feed the speakers?...is it a problem that it is already an amplified signal going into an amplifier...
    Also, when you say it doesn't sound that good, do you mean that it sounds bad, or it doesn't sound like a $200+ system.
    Elsewhere
    Quote Originally Posted by ph7ryan View Post
    Yes.
    Yes.
    How about the Wiki?
    Dec 2008
    Atlanta
    soooooo...how do I fix it if you are suggesting me to do just that
    Elsewhere
    How about the Wiki?
    Dec 2008
    Atlanta
    oh...nope never saw the faq's...I read the whole wiki, so I thought that it was the same thing...Thank you for now...
    Mar 2006
    ok onboard audio, you probably have at a minimum 3 jacks. Most motherboards can convert that to either 2 channel (normal with line out, line in, mic in), 4 channel (converts line in to another output) or 6 channel (5.1 audio no inputs). Also onboard audio is NOT amplified. Nothing coming out of a PC's audio jack is amplified to where it can be heard through speakers without more amplification.
    Really I only needed 2 channel since I have a coupe, and I found with having 4 channel, it was too much in the car to have the music whizzing around you. So I put it back to the standard 1 output jack which is 2 channel, converted that to 2 RCA's ran it to the amp, and used 2 y-splitters at the amp. So really I am using it as a 2 channel amp.
    And it does not sound bad. I have some people say it sounds great. But it is usually just me in the car, and I love it. I have heard people's sound system that they spent hundreds on, and one that the guy spent over $2000 on speakers and amps alone. They sound the same to me.
    And it was blue and shiny so it matched my car. The important things
    Dec 2008
    Atlanta
    Quote Originally Posted by 2k1Toaster View Post
    That was awsome...Everything I needed perfectly answered...I would love to know how to convert the minimum 3 jack audio into a no input system with 5.1 channel audio...do you have a page to link me to it please...
  1. FAQ: Connecting your Car PC's Power and Speakers
    By da_kooz in forum The FAQ Emporium
    Last Post: 10-04-2009, 10:56 PM
  2. Problem with rear speakers in car
    By beaver700 in forum Newbie
    Last Post: 05-28-2006, 10:44 PM
  3. Replies: 62
    Last Post: 10-28-2005, 04:54 PM
  4. Replies: 19
    Last Post: 10-27-2005, 12:53 AM
  5. Replies: 3
    Last Post: 06-27-2002, 07:40 PM
Tags for this Thread
