Page 15 of 15 FirstFirst ... 56789101112131415
Results 141 to 147 of 147
Thread: Can regular 0 gauge wire work?
  1. #141
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by PaulF View Post
    Don't just spend the money. Do what I said with the multimeter, that's a sure shot way to check the alternator.
    What kind of battery do you have in your install?
    The stock battery.... I think its a Bosch.
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
  2. #142
    Jul 2007
    Miami
    I think its the alternator. I was answering another post about someones system that would not turn on because their car does not put out 12 volts. I was explaining that I had to lower mine to 11.5 inorder to get my Car PC setup to activate, and even then I had to put my engine into high revs the first time I try to get it to turn on, otherwise I get a low voltage error. The battery is fairly new, bought it in 2008, so that leaves the alternator. With me driving a truck the ALT should put out at least 14V and the fact that I have to do so much, means it isnt putting that out anymore. We will not really know until I get a volt meter and test. I cant believe I forgot about that issue.
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
  3. #143
    Constant Bitrate thewizard's Avatar
    Dec 2008
    I get 14.4 volts at idle with the stereo and computer running, however not fully cranked up. You have the same 130amp alternator so I would have to agree that yours in pouched, either that or you have a short somewhere in your electrical system which you could easily diagnose with a multimeter.
    Data911 M5 system
    RR and iGo8PC
    Pioneer head unit
    Pioneer DEQ-9200 digital processor
    Phoenix gold line drivers
    Ultimate and Visonik amplifiers
    SMT 3 way active front stage
    Digital Design sub woofers
    3 runs of 0 gauge wire
  4. #144
    Jul 2007
    Miami
    Quote Originally Posted by thewizard View Post
    Is there a specific type of multimeter I have to buy? Also what do I test? From the battery posts, but any place else?
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
  5. #145
    Jan 2008
    Dartmouth, MA
    You've been working on an install for how long and don't have a multimeter?
    Just get a digital multimeter. All we need it for is DC volts. I've never seen one without it.
    You can test it from the battery posts if you want to, but that's hard to do when driving... any unregulated positive/negative line in the car works (any line other than a power supply's output). I would make a cigarette lighter hookup of sorts for ease.
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
  6. #146
    Jul 2007
    Miami
    LOL, I know..... I have never needed one. Only thing I usually check is polarity, and that I do with a LED bulb, wire and a 9V battery, lol.
    Anyways, it is the alternator, I am sure of it. I think maybe the past CAR PC units have killed or damamged it. I am going to upgrade the alternator when I have some money.
    I decided to do some experimenting with the wires. I really wanted to add a engine to chassis ground, so where the old engine to battery line was, I put it from there to the chassis, then from a alternator bolt to the battery went another wire. I then ran a new chassis to battery and down graded the old battery to chassis to a 4 gauge wire. The car doesnt like it, lights dim alot, so I am going to change it back. Only thing I will keep is the engine to chassis, the bolt is big enough to fit both engine to battery and to chassis. As for the chassis to battery is this a good ground point? Its part of the chassis, but not sure if its a good area?
    Also here is the point from the engine to the chassis. i plan to add the engine to battery also back on. That should clear things up.
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
  7. #147
    Jul 2007
    Miami
    OK, I haven't kept this thread up to speed, but i did change the wiring back to stock, or should I say the way Dodge had it, but with 0 guage. I did not want to over complicate things. I finally got the new alternator in, but I have some concerns.
    This question is for "thewizard" since he has the same engine as me, if anyone else knows, your welcome to answer. The new alternator has its own power regulation and exciter built into it. Turns out that Dodge though, was retarded and had to complicate things by making the ECU control the power regulation. My question is, how do I prevent the ECU from throwing up error codes since it will think the alternator is now missing? I know the old alternator had 2 wires, and the new alternator has 3 wires via a special cable. I do not know what the wires of the old one do, but I know it connects to the ECU. On the new unit, one wire is for ignition, the second is for the battery light, and the third is for constant 12V. I do not need any of these do I?
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
  1. Replies: 3
    Last Post: 05-20-2007, 09:23 PM
  2. finding connectors for 10 gauge + wire
    By VW_Carputer in forum Newbie
    Last Post: 05-31-2006, 01:10 PM
  3. What gauge wire from lcd?
    By hornyleprechaun in forum LCD/Display
    Last Post: 05-24-2006, 03:08 PM
  4. What gauge wire?
    By legend5761 in forum Power Supplies
    Last Post: 11-08-2004, 12:46 PM
  5. Will OPUS work with regular P4 Motherboard
    By badandy4you in forum Power Supplies
    Last Post: 06-22-2004, 01:55 AM
