Page 1 of 15 1234567891011 ... LastLast
Results 1 to 10 of 147
Thread: Can regular 0 gauge wire work?
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    I need to upgrade my amp kit from 4 gauge to 0 gauge. I was wondering though If I can simply go to Home Depot and use that type of 0 gauge wire, or does it have to be for the car? Unlike most people, I actually run my AMP kit wire under the car, and I noticed 0 gauge from Home Depot has a flat black coating that matches the undercarriage. I know some of you are saying, why not run the wire through the car, and or, aren't you worried about fire? Its to thick, and I am worried that I will have issues with EMI and if the wire were to over heat, it will not burn inside the cabin. If its out side, I don't have to worry about EMI, nor do I have to worry about fire, if it does burn I can drive into a water puddle or the wind will blow it out. Not that it would ever burn in the first place. Also my truck is long, so the run is long. When I installed the 4 gauge kit, I had to buy 2 of them to reach from the engine to the back. Also my install is huge with so many speaker, USB and other cables already taking up most space.
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
    Jan 2008
    this is one of the very few audio things that you must get the auto-grade wire.
    the home depot '0' gauge is meant to carry ac voltage, and is never meant for dc, and would be imposible to run anywhere.
    auto grade also has more conductors that will help carry the power farther, and is easier to run because it is more flexible.
    also, make sure that you get oxygen free copper wire, and not the new junk called cca, or copper coated aluminum-- the only advantage to it is that it costs less when you buy it.
    with the install that you are doing, it might not hurt to have 2 or 3 runs of 0 gauge just to make sure that you are never in a situation where the wire gets warm.
    Jul 2007
    Miami
    Quote Originally Posted by soundman98 View Post
    Thanks for the insight. Maybe I should explain my setup. I will most def go with auto grade, I didn't think about the AC/DC situation. The flexibility I didn't care to much about, I wanted it to be stiff.
    First from the battery it goes to a fuse, then to the bottom of the driver seat. Then a 0 gauge 3 way splitter is used to run to another fuse that leads to a 4 gauge wire to the PC. Then on the last port on the splitter, it goes to the rear to a 4 way 4 gauge splitter. One 4 gauge line goes to one of 3 PDX amps. The last 4 gauge line is for the 3 M4-ATX and a few other devices like rear camera, and thats about it. Do you still think I would need two 0 gauge runs. I mean I know people that run monster audio systems and I have never heard of a dual run?!
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
    Jan 2008
    thinking while i am typing:
    thewizard has 3 runs of '0' gauge...
    do the pdx series take a 4 or 8 gauge wire? i can't remember...i think they take 8...
    a pdx will take a 8 ga wire each, the m4(s)will really only need something like a 10 ga each, teh rear camera should be able to use 16 ga..
    so you would need 3-8 gauge, 1-10ga, and 1-16ga for camera? then you might be fine with one run of 0, but 2 will only hurt your wallet, and could help later.
    Vendor - Qube colin's Avatar
    Dec 2006
    Okay okay okay, it doesn't work SO much like that. The more connectors, the better -- yes. The better the copper, the better -- yes.
    However, you can use Copper Clad Aluminum if you want! It handles a ton of amperage. You can also use the Home Depot wire IF it has enough strands.
    The thing about wiring is that it is VERY VERY difficult to actually tell the difference. I've done countless hours of research on this (and still went with auto grade wire, for the record), and I decided that it is NOT that important. Speaker wire is the only iffy part, and thats because some people insist they can hear the difference. If you have the resources, do a quick test.
    The reason you might want more strands for this type of run is that the resistance should be lower. Resistance is your enemy in power runs.
    You COULD get away with other wire if you wanted to. You would probably never notice a difference once it's installed. Lots of strands though, don't want a ground loop.
    Jul 2007
    Miami
    The PDX has an option for 4 or 8 gauge. I think the bigger 1000 watt units take the 4 gauge. I am running the 500 watt versions so technically 8 gauge will work, but I feel more comfortable with 4 gauge. For the other devices I have distrubution blocks for all of that. I am not concerned to much with the wallet, but more on space. One reason I went with the PDX is because I hear the power draw is better that you dont need as thick of wire. They are also more effecient. So I figured one 0 gauge would work. Basically I have the potential to be pulling about 2280.00 watts, if I add the front PC, 320 watts, plus about 50 watts in devices. So 2650.00 watts of potential draw. i doubt I will hit that though.
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
    Jun 2009
    London, United Kingdom
    I've never understood the difference too well myself lol, I've got about 15m of 230v 5a household wire running in my van powering 3 cameras (reverse, cargo area and slide door)... Worked out fine and cost me next to nothing compared to automotive cable.
    I guess it's all down to the amps required, the cameras use less than 1 amp combined (guessing), so there's very little load... Where as a higher power demand could generate a lot of heat as well as being exposed to excess heat from various sources in the car/van... This is where household cable could cause problems as the shielding maybe less resistant to heat.
    Jul 2007
    Miami
    Quote Originally Posted by colin View Post
    So your saying the more strands i get the lower EMI issues I will have? I know with my previous install I had to use GLIs on all my audio channels. I am hoping that me running high grade speaker wire, and being carful how I run electrical will eliminate the need for GLIs.
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
    thekl0wn's Avatar
    Apr 2005
    PoCo, Indiana
    If you can find out the manufacturer of the welding lead wire at your local welding shop, you can find out what type of wire it is... Welding lead is the ONLY other type of wire I'd suggest contemplating.
    However, my best suggestion would be to check with KnuKonceptz... I've used them before, and know tons of other people from another forum who use them regularly, and have never had an issue. (I've only used their mobile stuff wire/distro blocks/fuse holders) Personally, I'm sold on their products.
    Play with it, 'til it's broke.
    Constant Bitrate thewizard's Avatar
    Dec 2008
    Welding wire works very well and is the cheapest feasible option. I would never even consider using household wire in a vehicle, it is a completely different animal that will not adequately carry a heavy DC load regardless of how much of it you run. It is designed to carry high voltage rather than low voltage, and high voltage loads operate with lower amperage, the opposite of a car audio system. In my particular case my system is capable of pulling an unbelievable amount of amperage, and the 3 runs of "0" gauge is to help keep the voltage drop to a minimum. Voltage drop is an amplifiers worst enemy, it will cause the amp to heat up faster, cause noise in your system, cause other electronic and electrical parts of the vehicle to fail sooner, and last but not least,,, cause your amplifier to make less power than the amplifier was rated to produce.
    Data911 M5 system
    RR and iGo8PC
    Pioneer head unit
    Pioneer DEQ-9200 digital processor
    Phoenix gold line drivers
    Ultimate and Visonik amplifiers
    SMT 3 way active front stage
    Digital Design sub woofers
    3 runs of 0 gauge wire
  1. Replies: 3
    Last Post: 05-20-2007, 08:23 PM
  2. finding connectors for 10 gauge + wire
    By VW_Carputer in forum Newbie
    Last Post: 05-31-2006, 12:10 PM
  3. What gauge wire from lcd?
    By hornyleprechaun in forum LCD/Display
    Last Post: 05-24-2006, 02:08 PM
  4. What gauge wire?
    By legend5761 in forum Power Supplies
    Last Post: 11-08-2004, 11:46 AM
  5. Will OPUS work with regular P4 Motherboard
    By badandy4you in forum Power Supplies
    Last Post: 06-22-2004, 12:55 AM
