it would be best if this thread were moved to the general car audio section, as the FAQ is for, well, fequently asked questions...
i really think taht the aftermarket harness is the a very good idea-- not to use in the install, but to use the color codes-- the aftermarket harness will be very clearly labeled, and from there you should be able to determine without a doubt which wire is which.
LinkBack URL
About LinkBacks
