Results 1 to 5 of 5
Thread: How to remove a MK6 Dash? 2002
    Jul 2009
    Hi
    I have tried looking to see if anyone has detailed info about removing a MK6 Dash.
    I have found http://www.mp3car.com/vbulletin/newb...rd-fiesta.html
    But I can't see how you remove the dash?
    I get as far as all the screws out, the dash coming forward, but then I am stuck with the Air control dials.
    Is there any clear pictures or info on exactly where you suppose to unclip this, or can I unscrew this as I see two screws holding this part to the dash?
    Jun 2005
    chicago, Illinois
    You need specific tools to remove the radio. If you notice there are small little slits on the sides of the radio, Click here.
    PROGRESS:
    Jul 2009
    Quote Originally Posted by pancit175 View Post
    Sorry, if I not made this clear.
    The car is a Ford Fiesta 2002.
    It doesn't need that tool as it's the Air control section which is preventing it from moving forward enough to get to the unit.
    Jun 2005
    chicago, Illinois
    Sorry I'm not very familiar with that car since it is not available in the U.S.
    Although, I would guess that you need to pull out the HVAC knobs in order to access the screws that is holding the dash on. Make sure that the knobs are at 12 o'clock before you attempt to pull them out. Either that or you need to release the opposite sides of the cable driven line, temp control etc. Those are typically found under the left side dash.
    PROGRESS:
    Jul 2009
    Removed mine last week. You can remove the heater matrix cable and circulation plug easily. On the right, the circular plug should pop off. Tricky part is the middle control. Unhook the wire, press the two pins towards each other and pull the cable gently.
  1. 2002 Montero Limited Install...
    By Squid in forum Show off your project
    Last Post: 10-06-2009, 03:41 PM
  2. 2005 Chevy Silverado Z71 Nano ITX Project
    By jwh02017 in forum Worklogs
    Last Post: 01-25-2008, 06:18 PM
  3. Help on custom dash for Caddy STS
    By Slaughterhouse in forum Fabrication
    Last Post: 12-14-2006, 06:47 PM
  4. Fs: Custom Escalade Dash & Carputer!!
    By EsKALad in forum Classified Archive
    Last Post: 11-09-2006, 10:24 PM
  5. 2002 Maxima Custom Dash
    By replicant in forum Fabrication
    Last Post: 08-28-2004, 05:49 AM
