if by "do the trick" you mean to produce sounds from you PC then yes. If your asking is that an amp that will produce high end sounds then no.
is this amp a good amp?
JENSEN UPA424
http://cgi.ebay.com/NEW-JENSEN-UPA42...d=p3286.c0.m14
will this do the trick?
Jensen Phase Linear UPA424CS - amplifier specifications
* General
* Product Type Amplifier
* Recommended Use Car
* Width 9.1 in
* Depth 2.0 in
* Height 6.7 in
* Audio System
* Amplifier signal-to-noise ratio 70.0 dBA
* Amplifier max output power / channel qty 60 Watts x 4
* Amplifier continuous power / channel qty 18 Watts x 4
* Amplifier output 4-channel
* Amplifier high level inputs Yes
* Amplifier input signal voltage 0.3 - 8V
* Amplifier total output power 240.0 Watt
* Amplifier Output Details 18.0 Watt - 4.0 Ohm - THD 1.0 % - 14.4V DC - 4.0 channel(s)
* Connections
* Connector Type 1.0 x Audio line-in , Speakers output ( Screw-type )
* Miscellaneous
* Included accessories Mounting hardware
"You know what I mean? But at the end of the day, it is what it is." - The most articulate thing someone could say.
And someone correct me if i'm wrong, but I think most factory speakers are rated at four ohms. So you won't even get those 36 watts per speaker. It works, but it's not exactly gonna wake up the neighbors.
2003 Chevy S10
Truckputer Progress:
Planning.......[----------X] 100%
Parts...........[---------X-] 99%
Fabrication...[---------X-] 99%
Upgrades.....[X----------] 1%
do yourself a favor and get something with more power. That thing seems to have less power than many aftermarket headunits. And you want more power than you need, or you will be stressing the amp and you will get more distortion. No one who buys a 800 watt amp for speakers actually uses the 800, but the speakers dont sound underpowered.
Acer Netbook with 160hdd and 1.60 Ghtz atom - to be installed
Afro.. I just bought this one .. is this okay?
Technical Details
* 2200W
* Freq Resp: 12 Hz¿22 Khz (+/-3Db)
* Low Pass Crossover On Channels 3 & 4 @ 120 Hz (Fixed)
* Variable Input Gain Control
* Power & Protection Led Indicators
› See more technical details
Product Details
* Product Dimensions: 10.7 x 9.2 x 3.5 inches ; 4.9 pounds
* Shipping Weight: 4 pounds (View shipping rates and policies)
* Shipping: Currently, item can be shipped only within the U.S.
* ASIN: B000O554HU
* Item model number: 4F400
* Average Customer Review:
2 Reviews
5 star: (0)
4 star:
(2)
3 star: (0)
2 star: (0)
1 star: (0)
› See all 2 customer reviews...
4.0 out of 5 stars See all reviews (2 customer reviews)
* Amazon.com Sales Rank
Popular in this category: (What's this?)
#4 in Electronics > Car Electronics > Car Audio & Video > Amplifiers > Multichannel Amplifiers
* Date first available at Amazon.com: March 13, 2008
Would you like to update product info or give feedback on images?
Product Description
Product Description
Sound Storm Laboratories is a multi-million dollar full-line car audio manufacturer.Sound Storm was established in 1997 by a group of car audio professionals whose goal was to bring exciting product designs to the mobile electronics market at affordable prices. This ¿more-bang-for-the-buck¿ philosophy was incorporated into every aspect of the company. The 4F400 four channel amplifier kicks out an impressive 400 watts of maximum power. The built in variable low pass crossover and variable input gain control allows you to tune your bass just how you like it. For high quality product at an affordable price, give SoundStrorm a try!
Should be much better. Im sure that'll be fine for anything but high end component sets. Granted I dont know how good the brand is.
checkout the learning center in crutchfield. it has a cable gauge chart and step by step instructions.
