+ Reply to Thread
Results 1 to 7 of 7
Thread: Factory amp's harness to new amp
    Low Bitrate titanicmusic14's Avatar
    Jan 2008
    Pennsylvania
    is that possible to use the factory stuff on the low watt amps?
    "You know what I mean? But at the end of the day, it is what it is." - The most articulate thing someone could say.
    Jun 2004
    Rochester
    Absolutely. If you are replacing the factory amp with an aftermarket one because you can't interface with the factory stuff, yes. If you want to replace it so you can get more power out of the system then you should run new wires. Just be sure you know what you are hooking up to as far as the factory wiring (impedance, factory crossovers, etc). Myself, I like to interface with the factory amp equipment when possible as it is matched to the factory speakers and often has built in equalizers to make the cheap factory stuff sound pretty decent.
    ** Denotes an "in car" post
    In-Car posts made from passenger seat - Be safe, Don't Post and Drive.
    Jan 2008
    Pennsylvania
    reword
    Quote Originally Posted by walky_talky20 View Post
    What I meant was, is it possible to use the power from the harness of the factory amplifier to the 400w amp that I just bought or do I have to run that 8 guage wire to it from the battery. I'm scared I might start a fire or something but I feel like I will have a less chance of alternator whine if I use the factory amp's power harness.
    Constant Bitrate thewizard's Avatar
    Dec 2008
    Run a new power wire from the battery. The factory amps wiring will not supply adequate power for an aftermarket amplifier. Also I would not run anything less than a 4 gauge wire, it's a waste of time and money.
    Data911 M5 system
    RR and iGo8PC
    Pioneer head unit
    Pioneer DEQ-9200 digital processor
    Phoenix gold line drivers
    Ultimate and Visonik amplifiers
    SMT 3 way active front stage
    Digital Design sub woofers
    3 runs of 0 gauge wire
    Jan 2008
    Pennsylvania
    MR. m2-atx
    Quote Originally Posted by thewizard View Post
    and what about the m2atx can it share a line with it?
    Dec 2008
    Yes it could.
    Data911 M5 system
    RR and iGo8PC
    Pioneer head unit
    Jun 2006
    Mobile, AL
    the M2-ATX can use just about any of our extra power drops. The one I found that worked good was under the passenger dash. It has a constant, an Ignition based on key position, and a ground. It is also fused individually for 15-amps.
+ Reply to Thread
  1. connecting amp to speaker wires in OEM harness
    By azlunchbox in forum Car Audio
    Last Post: 03-18-2009, 03:46 PM
  2. pc to factory harness
    By 01pewterz in forum Newbie
    Last Post: 03-15-2007, 08:45 PM
  3. adding a amp to factory bose system
    By wyldbill in forum Car Audio
    Last Post: 08-20-2005, 05:23 PM
  4. Replies: 25
    Last Post: 08-04-2005, 12:49 PM
  5. Replies: 13
    Last Post: 04-15-2005, 03:55 PM
