Results 1 to 4 of 4
Thread: ls_fiter(4 way activ) vs 4 instance of ruberfilter
    Jan 2009
    wich would be a better choice
    ls_filter : 4 way active setup, (one instance) 3 filter type ..bessel...buterworth...Linkwitz 6 to 24 db....the downside is that their is a 3 band equalizer per chanel ...but we cannot really touch it ...and the 3 band equalizer has already 3 values (?????????????????????)
    http://www.ohl.to/about-audio/audio-softwares/ls-filter
    or rubberfilter :
    need 4 instances..
    The free Rubber Filter VST plug-in by Christian Budde is a highly versatile 6-384 dB/Oct filter. It features low pass, high pass, band pass, and band reject (notch) filtering, with individual control of left- and right channel.
    i think it is all buterworth filter
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    You can also try Electri-Q. They have free version "Electri-Q - posihfopit" which have EQ crossovers...
    LINK
    Jan 2008
    i personally use individual butterworth/chelbychelv filters for each output, but this is mostly becsue i hate relying on one plugin for all my crossovers, and really don't want to take the time to learn how to use lsfilter, or electri-Q.
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    Quote Originally Posted by soundman98 View Post
    electri-Q is very easy to use
    First you select Linear Phase mode, right click and hold on one point select filter type and double click on point to enter frequency, gain and that is all Very easy and you see on real time EQ curve...
  1. Dual Instance, one winamp, cross-control
    By InfinitiPC in forum Road Runner
    Last Post: 12-09-2008, 02:04 AM
  2. How to add a Digital Output instance to your configuration file
    By 2k1Toaster in forum FB Documentation and Tutorials
    Last Post: 06-07-2008, 12:20 PM
  3. How to add a Fusion Brain instance to your configuration file
    Last Post: 06-07-2008, 09:42 AM
  4. Centrafuse 1.42 Update
    By veetid in forum Centrafuse
    Last Post: 11-25-2007, 04:41 PM
