Results 1 to 9 of 9
Thread: How would this amp measure up?
    Newbie thejavabuddha's Avatar
    Jul 2009
    Boss CX350
    Product Features
    Single 4-channel power amplifier
    Sensitivity: 90 dB
    Power output: 50w x 4 RMS, 100w x 4 Max
    Line and speaker level inputs
    MOSFET power supply
    Technical Details
    Power handling: 50w x 4 RMS, 100w x 4 Max
    Sensitivity: 90 dB
    Inputs: Line and speaker level inputs
    Trimode operation: Yes
    Bridgeable: No
    Remote subwoofer level control: Yes
    Bass boost: 0-+18dB variable bass boost
    Variable gain control: Yes
    Indicators: Power and protection LEDs
    Crossover: Variable lowpass and high pass crossover
    Power supply: MOSFET
    Dimensions: 7.5 x 9.8 x 2.2 inches
    Weight: 3.6 lbs
    Low Bitrate jake789's Avatar
    Apr 2009
    Personally I wouldn't bother with Boss. They are the bottom of the line for amps.
    Constant Bitrate thewizard's Avatar
    Dec 2008
    I'll second that, they should have just stuck with headphones.
    Data911 M5 system
    RR and iGo8PC
    Pioneer head unit
    Pioneer DEQ-9200 digital processor
    Phoenix gold line drivers
    Ultimate and Visonik amplifiers
    SMT 3 way active front stage
    Digital Design sub woofers
    3 runs of 0 gauge wire
    Jan 2008
    i also agree with them, though if you are on a tight budget, and really can't afford a name brand amp, it will work fine, and will amplify sound. but there are better(also, more expensive), name brand amps out there that will will do it better, but are more reliable.
    Jul 2009
    I AM on a budget and just pushing stock speakers in my '05 VW Jetta. I want/need something under $50.00. Anything better for the price? Would this sound as good/better than the stock HU? Thanks for the info!
    Jul 2009
    Oh, and one other thing since I am a COMPLETE noob when it comes to car audio; since the front speakers are split into separate tweeter, mid and woofer...do I need any special considerations when looking for/hooking up an amp to them? Or do they all get twisted together and put on one channel?
    Thanks again!
    Bill
    Mar 2006
    Colorado, but Canadian!
    If you just want it to sound like a HU, you can get any amp really.
    1.9in x 2.9in -- 47mm x 73mm
    Elsewhere
    Quote Originally Posted by thejavabuddha View Post
    Thanks again!
    Bill
    There are a lot of unknowns there.
    Chances are there is a crossover for those front speakers. There is one signal line that goes to the crossover and that sends the highs to the tweeters and the rest of the audio to the midrange. In that case, you simply run your front channels to the crossover and you are good to go.
    Mind you what I described is the most common setup, and may not be how your speakers are wired.
    Since you know you aren't knowledgeable about car audio, it's time to learn. I suggest taking your car to someone who is, be it a car audio shop (who will probably charge you), a friend, or someone at a car or car audio show. Have them look at your front speakers and determine what you need.
    How about the Wiki?
    Jul 2009
    FYI, I ended up going with this one after doing way too much/not nearly enough research. There is a LOT to know about amps!!! $50.00 used on craigslist.
    •70 watts RMS x 4 at 4 ohms
    •140 watts RMS x 4 at 2 ohms
    •280 watts RMS x 2 bridged output at 4 ohms
    •2-, 3-, or 4-channel output
    •4-ohm stable in bridged mode
    •Tri-way capable (Tri-Way crossover required)
    •requires 4-gauge power and ground leads — wiring and hardware not included with amplifier
    •PWM MOSFET switching power supply
    •variable 50-200 Hz high-pass/low-pass crossovers (12 dB/octave high-pass, 24 dB/octave low-pass)
    •ThunderEQ bass boost (up to 18 dB at 40 Hz)
    •preamp outputs
    •13-15/16"W x 2-1/8"H x 9-3/4"D
  1. Replies: 38
    Last Post: 11-30-2010, 06:04 AM
  2. another 'my amp fuses keep blowing'
    By curious12 in forum Car Audio
    Last Post: 07-06-2009, 09:28 AM
  3. Amp running hot...??
    By Emerica2843 in forum General Hardware Discussion
    Last Post: 02-08-2006, 06:40 PM
  4. Replies: 3
    Last Post: 12-07-2004, 07:34 PM
