Results 1 to 10 of 17
Thread: 1/2 din radio?
    Newbie myleskeller's Avatar
    Aug 2009
    1/2 din radio?
    i have a pontiac with the stupid 1.5 din opening.
    i want to buy http://cgi.ebay.com/VMI70-7inch-IN-D...QQcmdZViewItem.
    its great, but it doesn't have a freakin radio of any kind. only an audio out.
    so i was hoping to find a stereo that fits in a 1/2 din dash opening. i know they make an in-dash vga touch screen that fits in one, you think they can make a simple stereo that fits in the same space.
    ...or in the case that doesn't exist, maybe a way to cram a full size one into a 1/2 din opening?
    Jan 2008
    i have never seen a 1/2 din radio--- how about just installing a full car computer and adding a radio tuner?
    May 2009
    Florida
    Your install will look better if you use a standard 7" wide screen monitor instead of one of those slide out types. My Xenarc fits perfectly behind my 1.5 din Pontiac bezel, I did have to do a little cutting inside the dash to make room but I didn't do any fiberglass molding of the bezel at all and it looks factory.
    Aug 2009
    could you please post a picture?
    Aug 2009
    i don't see how a double din screen could be entirely visible behind a 1.5 din bezel.
    May 2009
    Florida
    Sorry for not responding sooner, I have been neglecting my e-mail. This is the only picture of my install that I have online right now. as you can see, the buttons are hidden behind the bezel but the remote still works so that is OK. The entire screen is visible through he factory opening and since the opening is smaller than the overall monitor dimensions I didn't need to fill in any gaps.
    Aug 2009
    amazing!
    what model xenarc monitor is that?
    and did you make a guide (or have any useful info) about installing it?
    May 2009
    Florida
    The monitor is a xenarc 700tsv. Unfortunately I did not document my build process but fitting the screen in was surprisingly simple. I thought it would be much harder and require fabrication but once the radio is out the monitor fit behind the bezel even without modification. the plastic shelf that the radio sits on blocked the lower part of the monitor making the monitor sit to high and the top of the screen was not viable. A little cutting with a dremel and the problem was solved. I used simple velcro to make the monitor stick in the exact spot I wanted.
    Aug 2009
    great. what did you use to replace the head unit to power the speakers?
    i've seen people use 4 channel amps but was wondering what you used.
    May 2009
    Florida
    New speakers and a 4 channel amp. I may have been able to get away with not replacing the speakers but factory speakers don't usually work to well with after market amps.
  1. Class 2 Data Bus
    By owenjh in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-09-2008, 04:34 AM
  2. Question on double din
    By jdiazj1 in forum Newbie
    Last Post: 02-08-2006, 04:54 PM
  3. wintv radio not launching when i press radio
    By dnkyntz in forum RR Bug Tracker
    Last Post: 12-23-2005, 02:49 AM
  4. 1/2 din AM/FM radio ????
    By spectrrr in forum General Hardware Discussion
    Last Post: 10-08-2005, 08:45 AM
  5. Possible to build a computer that'll fit in a 1/2 DIN slot?
    By WWE-TicK in forum General Hardware Discussion
    Last Post: 03-27-2004, 01:46 PM
Tags for this Thread
