Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Advice needed please, FM transmitter interference when power applied to laptop.
  1. #11
    Constant Bitrate thewizard's Avatar
    Dec 2008
    What laptop are you using and what DC voltage does it require? I always had noise issues whenever I tried to run a laptop using an AC-DC adapter and an inverter, but as soon as I found a DC-DC adapter for whatever laptop I was using it was always was clean as a whistle, and this includes the Aspire One that I currently use. The on-board high definition audio in these little laptops produces absolutely incredible sound quality from the line out, although I do run it through a DSP prior to amplification.
    Data911 M5 system
    RR and iGo8PC
    Pioneer head unit
    Pioneer DEQ-9200 digital processor
    Phoenix gold line drivers
    Ultimate and Visonik amplifiers
    SMT 3 way active front stage
    Digital Design sub woofers
    3 runs of 0 gauge wire
  2. #12
    Apr 2008
    im using a dell e1505 which i bileave uses 19.7 volts. im using a direct adapter from the cig light to charge it, not an ac-dc inverter. wats a dsp? prior to this i was using an asus 1000he without any problems, probably because that used a 12 volt charger, so there was no power brick, just a straight wire.
  1. linking into laptop power button
    By corsamel in forum General Hardware Discussion
    Last Post: 04-23-2010, 05:53 AM
  2. HOW TO:use opus with a laptop......
    By turbocad6 in forum Power Supplies
    Last Post: 06-25-2009, 07:31 AM
  3. What Power Supply for Laptop Install?
    By D3LTR33 in forum Newbie
    Last Post: 08-04-2008, 07:41 AM
  4. Maintain power to laptop for Wake to work?
    By frontier in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 04-09-2008, 04:29 AM
  5. Startup/shutdown and power advice for a laptop?
    By spinedoc in forum Power Supplies
    Last Post: 08-22-2005, 09:04 PM
