Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: How do I go louder?
  1. #21
    Jan 2008
    Quote Originally Posted by smartass365 View Post
    I know it's taking a step backwards,
    but did you check the gain setting on your amp?
    he is using the factory amp, so this should not be an issue--though if it was a aftermarket amp, it would be a good thing to check.
  2. #22
    May 2009
    yep. that's an issue that could be solved with an aftermarket amp, but with an 8 speaker sound system, I'd have to buy (2) 4 channel amps, and I have no idea what the wattage on my speakers is.
  3. #23
    Jan 2008
    typically, a small 4 channel, 50-75 watt max amp should be enough to power the factory speakers-- just make sure that each speaker has a acceptable crossover.
  4. #24
    May 2009
    with 2 tweeters, 4 mids, and 2 subs, would I be able to run (2) 4-channel amps? Or should I run (1) 4-channel for the mids and (2) 2-channel amps, 1 for tweeters, 1 for subs?
    I dont think I have enough outputs for all that...
  5. #25
    Dec 2008
    if youre using vista or later, there is a good chance windows installed an option with your sound card to limit its output... by default this gets sets to ON, and if you turn it off it will allow full output and much louder sound.
  6. #26
    Jan 2008
    Quote Originally Posted by trader007 View Post
    yet another reason for me to hate anyhting after xp(my first reason is not allowing boot screen changes in win 7)
    for a install like that, you would typically use one 4 channel for the mids, and then a 2 channel for the tweeters, and either one 2 channel amp, or two 1 channel, high power amps for the subs. it would be neccesary though, to find out the specs for the subs before buying any amps for them--the other speakers should be able take a 22watt rms(50watt max) amp fine.
  7. #27
    Dec 2008
    its actually a feature. vista revamped the entire audio stack for windows, and even with basic onboard sound you can now have features only found on high end home theater receivers. the limited output is just the same as what you find on ipod's, its very simple to turn it off, and while youre in that menu you can take a look at other audio enhancements too.
  8. #28
    May 2009
    That's interesting, but I'm running a chopped down version of windows XP using nlite.
  9. #29
    Dec 2008
    its most likely your hardware then, it just doesnt have a strong output. most newer motherboards nowadays preout a level that is stronger then most cd players, radios or whatever....
  10. #30
    Aug 2006
    Did the output go down when you switched to to the carpc from the stock/aftermarket headunit?
  1. Replies: 0
    Last Post: 10-15-2007, 11:20 PM
  2. louder output from external soundcard
    By Dj-[NRG] in forum Hardware Development
    Last Post: 07-28-2007, 11:49 PM
  3. Lilliput GL701 wont go louder
    By mrborrie in forum LCD/Display
    Last Post: 07-09-2007, 06:31 AM
  4. FP louder than RR?
    By kameleon in forum FrodoPlayer
    Last Post: 09-22-2005, 08:55 AM
