Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 33
Thread: eq
  1. #11
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    Quote Originally Posted by summer69guy View Post
    did you try with and without the EQ?
    Both give me same result!!!
    I THINK that Im find fix for my sistem:
    1.) In BIOS Im disable C1E
    2.) Im decrease for 2 points hardware acceleration
    Now I think work ok. I get after few hibernates crackling back so I must stop and start audio in Console...
    As EQ I use Electri-Q(Linear Mode and Bugpass filters) for me is very simple VST plugin easy to set up but cant be used for 2 channels(You must use for each channel own plugin)...
  2. #12
    Jan 2009
    so you dont have weird sounds anymore?
  3. #13
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    After normal boot no but after few hibernates yes. Looks like that I must erite plugin for CF which will stop sound before hibernate and enable it after resume
  4. #14
    Jan 2009
    i think but i' not sure if you put the sound card in 44.1 khz mode...the sounds will be ok..
    it was in 192 khz before..
  5. #15
    Jan 2009
    but there is also minimal crackling sound
  6. #16
    Jan 2009
    i hope we are not alone with this problem..there is surely a solution..
  7. #17
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    Please do not post warez links again, this is against the rules and wrong. Links removed by me in case you were wondering. Carry on.
  8. #18
    Sep 2006
    Perhaps you find some of this info useful.
    http://www.thuneau.com/forum/viewtopic.php?t=97
    It's possible your PC specs are too low on resources, or you are using output plugins in the player software that VAC is not happy with.
  9. #19
    Jan 2009
    my cpu is on 30% load ..and i have a 1.6 dual coe atom 330
    thanks for your link
  10. #20
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    Sorry but 44.1kHz is not acceptable for me For this I can use Audison Bit One processor... I have a lot of audio material recorded in 96kHz/24Bit and would like listen it without resampling...
    Quote Originally Posted by durwood View Post
    Im not shure. My CPU usage in Task Manager is 5-10%
    I have:
    Intel P8400 CPU(2x2,26GHz)
    2GB DDR2 800MHz RAM
    80GB Intel SSD X25-M
    If this PC can't handle 3-Way audio system with 5 VST plugin for EX and 5 for TA then I don't know what to buy... But as Im say now I use only EQ plugins without TA plugins... Same problem is in Console or AudioMulch so host is not problem...
  1. New set of questions (digital outs, hardware eq)
    By BLACKonBLACK98 in forum High End Solutions
    Last Post: 12-10-2008, 04:32 PM
  2. Which EQ for HD radio?
    By ccrum in forum RR Skins
    Last Post: 06-24-2008, 11:26 AM
  3. RR 09-28-05... EQ stuff...
    By guino in forum Road Runner
    Last Post: 10-01-2005, 02:08 AM
  4. Which EQ?
    By accentsound in forum Road Runner
    Last Post: 07-18-2005, 04:09 AM
  5. Winamp 2.9x and 5.x EQ.
    By stevewm in forum Software & Software Development
    Last Post: 12-23-2003, 11:17 PM
