Page 1 of 4 1234 LastLast
Results 1 to 10 of 33
Thread: eq
    Jan 2009
    eq
    hi, when i put an eq plugin into audiomulch the sound has some kind of poping while the audio play.
    i when i remove de eq the soudn is good...
    do you know an equlazer wich do not do that...
    i tried Linear Phase Graphic EQ 2
    ElectriQ FULL
    THIS ONE : http://habib.webhost.pl/vst_eq31.php
    foobar is my audio player.
    when i use the eq of the sound card it is ok...but there are just 10 bands!
    Jan 2009
    it is not poping but the soudn have some grishing ...not alwyas......but frequently...like at each 10 sec...
    Jan 2008
    hmm-- i have a similar problem, but have been blaming my VAC and Asio4All... i guess i will need to try a different eq...
    try here--http://www.kvraudio.com/
    i have about 5 or 6 vst eq's from there...
    Jan 2009
    thanks a lot for your link! i found one which doeant make any bad noise !
    here it is you can try it maybe it will solve your problem.
    http://www.aay-audio.com/index_products_aQ-31.html
    no more noise for me
    here is the link to get it free !
    (link removed by moderator)
    Jan 2009
    with the full version it is written demo but it is not demo
    Jan 2008
    so i tried that vst eq- and the pops and audio studdering got worse-- i took out eq, and so far, seems to have fixed the entire issue! it is starting to look like i was excessivly over-eqing(new word?), and it was causing all of my audio problems-- my cpu stayed around 50-60% while playing any files with the eq, and has now gone down to 30-40% usage with no eq...
    so apparently trying to drop all frequencies 9db from 2khz-20khz was a bad idea(the only thing i was using the eq for)....
    Jan 2009
    yes i had som pops too...but less than with the other equalizers...i hop somebudo has a solution :S
    i dont understand why it makes that!
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    I researching cca. 1 week why I get crackling and popping with my sound card...
    Im find next things:
    1.) VAC is not problem. Why? Because if I use Audio Repeater(Included in VAC) and for input select VAC Line1 and output Claro Speakers then set 96kHz and 24Bit buffer and other stuff I leave as it is then All work as must without popping or crackling. CPU usage cca. 5%
    2.)Native ASIO drivers:
    -Winamp(Latest) + ASIO plugin -> A lot off crackling and popping no mather which Latency I use(2, 10, 40, 80, 150, 300). If I right remember at 300 I do not get anything to speaker and winamp crash a lot of times... No mather if I use drivers from manufacturer site or latest one.
    -WMP + ASIO Plugin -> Drivers from manufacturer page a lot off popping,latency do not fix it... Latest drivers look like work ok at 10ms and 20ms setting(I must retest again)
    3.)ASIO4ALL+VAC - Get crackling and popping Im not fully test alll options jet...
    Jan 2009
    did you try with and without the EQ?
    Jan 2009
    try this one (link removed by moderator)
    it has all of this feature in this pack :
    GEQ15V, GEQ31V - constant Q graphic equalizers
    12 dB of boost or cut at any of, respectively, 15 or 31 bands centered around International Standards Organization (ISO) 2/3 or 1/3 octave frequencies from 20Hz to 20KHz. The warmth of classic analog devices with the clarity and the accuracy of the digital domain processing.
    PEQ1V - parametric equalizer
    An intuitive interface that drives a powerful constant Q, minimum phase equalization algorithm. The tool of choice to control the equalizations of vocal parts, instruments or complex mixes.
    with those..it is the clearer sound i heard in my car And is has very minamal crackling...
  1. New set of questions (digital outs, hardware eq)
    By BLACKonBLACK98 in forum High End Solutions
    Last Post: 12-10-2008, 03:32 PM
  2. Which EQ for HD radio?
    By ccrum in forum RR Skins
    Last Post: 06-24-2008, 10:26 AM
  3. RR 09-28-05... EQ stuff...
    By guino in forum Road Runner
    Last Post: 10-01-2005, 01:08 AM
  4. Which EQ?
    By accentsound in forum Road Runner
    Last Post: 07-18-2005, 03:09 AM
  5. Winamp 2.9x and 5.x EQ.
    By stevewm in forum Software & Software Development
    Last Post: 12-23-2003, 10:17 PM
