Results 1 to 10 of 13
Thread: something makes my tweeter clipping ...and a little my midrange...
    Jan 2009
    HI....i got something making my tweeters cliping ...
    i do not really hear them...and when i put the sound up the clip....
    the problem appears with my midrange too...but less...
    i played with my gain...but thats not the problem...
    So i would like to know if is there a signal wich can do clipping in my speaker...(in the carputer)
    is there any level that i could lower in the pc? there are many level ajustment everywhere
    my setup:
    asus xonar 2d pci sound card...
    audiomulch
    lsfilter
    could it be my soud card wich has just 2 volt rms of outpout?
    wich makes my speaker cliping?
    Jan 2009
    if you dont understand i could try to explain more...
    Jan 2009
    maybe wungun you had a similar problem like that?
    should i just change the sound card?
    what can i do?
    Jan 2009
    or maybe it is the asiofor all.?
    is there a way to replace it?
    Jan 2009
    i am realluy starting to think it is the vac or the asiofor all....is there anyways to get sound without these?
    Jun 2005
    chicago, Illinois
    Sounds like a crossover problem.
    PROGRESS:
    Variable Bitrate rijndael's Avatar
    Apr 2007
    on Earth
    it could also be your cable from the sound card to your amp...had a problem similar to yours once, and that was the issue...my midrange on driverside was out completely, replaced the cable, no more issue.
    Trouble deciding on car speakers? Clicky Clicky
    Speakers: DLS Ultimate Iridium 6.3 Link
    Subwoofer: removed
    Amplifier#1 (Front Stage): DLS Ultimate A4
    Amplifier#2 (Sub) removed
    Carputer: Removed for tablet install
    Jan 2009
    i pluged the pc into my hosue....and i plug a headphone in the tweeter jack....
    it made the same thing...
    i try to put my xonar audio card into my other home pc...and the card was playing perfect....
    in my other pc i have windows vista...maybe it is taht....i know that wungun has two sound card with windows xp...but maybe he do not use this outpout(high)
    Jan 2009
    maybe a driver isssus with xp...
    or the carputer motherboard is not compatible with my sound card
    Jan 2009
    http://www.mp3car.com/vbulletin/powe...ing-my-pc.html
    go to see this topic...i almost found the problem...
