Results 1 to 4 of 4
Thread: doubling power?
    Aug 2009
    doubling power?
    This might be a dumb question but I honestly do not know the answer or if this will work. My head unit has four outputs for speakers. Front right ( +,- ), front left ( +,- ), rear right ( +,- ), and rear left( +,- ). Im only going to be running tweeters off of my head unit because the car speakers are going to be running off a seperate amp. If i connect the front left( + - ) output to one tweeter( + - ), then the front right( + - ) output to the other tweeter( + - ), each tweeter will only be getting 25 watts. Would I be able to wire the front right( + - ) output of the HU and the rear right( + - ) output from the HU together, then wire that to one tweeter to double the power so the tweeter would be getting 50 watts?
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    Chances are no. some amplifiers allow this, which is called bridging. Most headunits do not, and you are likely to damage the headunit in the process if you try it. Check the manual for the headunit and see what it says.
    Quote Originally Posted by mitchjs
    stop with the REINSTALLS, what do you think we got some lame-o installer!!!
    RevFE - Super fast, modular frontend. Most powerful skinning engine in existence. Strong enough for an i7 made for a fitpc.
    Just a shame I can't justify a carpc to use it on anymore.
    Constant Bitrate thewizard's Avatar
    Dec 2008
    Why would you need more than 25 watts to a tweeter anyhow? That should be ample unless you are running big percussion horns or something.
    Data911 M5 system
    RR and iGo8PC
    Pioneer head unit
    Pioneer DEQ-9200 digital processor
    Phoenix gold line drivers
    Ultimate and Visonik amplifiers
    SMT 3 way active front stage
    Digital Design sub woofers
    3 runs of 0 gauge wire
    Aug 2006
    some alpines let you bridge the rears for a mono output for a small sub but i have never seen the ability to bridge the front and rears together. but like the above said, read the manual..... but probably not.
  1. Replies: 115
    Last Post: 03-05-2011, 04:54 AM
  2. Hardware Review: M3-ATX Power Suply
    By Bimmerstyle in forum The Review Palace
    Last Post: 03-05-2008, 06:57 PM
  3. fried my carnetix power supply?
    By mustanglou in forum Power Supplies
    Last Post: 11-10-2007, 12:34 PM
  4. N00b Power Question
    By jamiewhittingha in forum Power Supplies
    Last Post: 03-25-2005, 01:08 AM
  5. Replies: 7
    Last Post: 06-15-2004, 10:29 PM
