Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 43
Thread: Someone please help with audio!
  1. #21
    Newbie armysgt's Avatar
    May 2009
    Electronic Space Foot
  2. #22
    Dec 2008
    ugh, it wants me to register to see it.
    can you copy the picture to imageshack.us and repost it here?
  3. #23
    May 2009
    ive tried my microsoft word isnt registered so it wont let me copy or anything.thats the only program that will let me open the doc. ill see if i can find it somehwere else
  4. #24
    Dec 2008
    Quote Originally Posted by armysgt View Post
    just save the doc and post it as a file with dropbox then. if you dont have dropbox, you live in a cave
    www.dropbox.com
    or, even easier should be megaupload.com so you dont have to install anything.
    edit- this forum allows file uploads too. just go advanced, and click on the paper clip.
  5. #25
    May 2009
    ok, i believe this worked, thanks so much for your help by the way.
    Attached Files Attached Files
  6. #26
    Dec 2008
    man that still really doesnt answer my question, i still have NO CLUE as to what type of wires go from your radio to your amp. if they are low voltage, then you dont need anything more. if they are high voltage, you need either a radio or a new amp.
    so we gotta find that out. lets go back to when you just tried it. hook up the brown (-) and white (+) to your computer output... just that channel, it should be the front left speaker. you said when you touch the + you can hear something, but when you add the ground it completely cuts out? make extra sure youre using the right wires.
  7. #27
    May 2009
    im gonna have to try this in little while,my car is a mess. ill get back to ya
  8. #28
    Dec 2008
    actually, here is a hint-
    12 Pin Connector
    Speaker-Level Inputs, Power/Ground
    that usually indicates high side inputs, meaning that could explain why adding the ground cuts it out (high side are a/c current, you add a ground to it and bye bye sound)
    i have a strong feeling youll need a new amp or add a radio. again, thats really your call completely, either way will work well.
  9. #29
    May 2009
    ok, so would that mean getting an aftermarket amp or head unit, or could i tap right into one of the stock amp's harnesses, im so confused sorry
  10. #30
    May 2009
    im sorry to confuse you, when i tried hooking the wires up, i hooked them to the harness behind the stock stereo, not the amp. i havent tried the wires on the amp yet
  1. Outputting from car audio head unit to home theater receiver
    By mach5 in forum General MP3Car Discussion
    Last Post: 05-31-2007, 12:20 PM
  2. 2005 BMW E46 CarX audio hook-up question?
    By reggs in forum Hardware Development
    Last Post: 09-24-2005, 04:06 PM
  3. CarPC audio problems
    By aal2000 in forum Car Audio
    Last Post: 09-07-2005, 09:40 PM
  4. Replies: 19
    Last Post: 12-04-2004, 06:37 PM
  5. Seperate VGA and S-Video with Audio
    By Fox_Mulder in forum General Hardware Discussion
    Last Post: 07-01-2004, 02:44 AM
