Hello,
I have been in battle with noise for a while. I run my setup using a 400W inverter and a Pioneer
head unit. So as some may know inverters are very noisy. I recently have eliminated 99% of the noise in my system ( yes EMI and RFI ). What I did is very simple. I ran the
power line for the inverter on the underside of the vehicle and
took pre-cautions against it becoming rubbed through and or damaged. The +12V was ran on the underside of the vehicle to keep it away from all other low voltage lines ( speaker cables, rca lines etc. ). I then ran a very
short ground to the vehicle body. Both lines were 8 gauge wire.
A few lessons I learned were the shorter the ground the better. The ground line has to be a larger and or same size guage than the largest +12V line you use in your system. If your setup is in a really modern vehicle you must find a ground point other than the body because most modern vehicles are designed around the uni-body method and it's componets are tack welded together at the factory. So my point is tack welds or other mechanical junctions will cause poor grounding so go after frame rails or the like.
As a final thought in regards to running heavy +12V lines. Always use a fusable link at the battery and use grommets where the line may pass through holes in the body and or frame of the vehicle. Make no exceptions, the last thing you want is this line to short to the frame without a fuse, all you have left of your car is copper and a frame!
C'Ya
Leo
