First you have to know if your factory amps take line signal or speaker-level signal. If they work with speaker-level signal you will need to send an amplified signal as it came out of the original HU.
In that case I'd suggest the Xtronic USB Amp.
Hi, I searched and found few threads but incomplete answering the same question. I want to be able connect my amp/speakers (Factory Bose) to my carpu soundcard with no headunit. The reason for that is because I upgraded to a 7" double-din which I took the factory HU to fit the screen. I might in the future get a alpine or pioneer HU. But now I want to used the amp without a headunit.
I found this item. Anyone think it works like how I want it to?
http://www.crutchfield.com/S-1zEkakL...PAC-OEM-2.html
Hello,
From my experience most amplifiers will work fine when connected to the the "line out" on your sound card. You will need a 3.5mm phono to RCA adapter or sometimes known as a mini "Y" adapter. Hope this helps!
Leo
if it is a factory GM bose, it will most likely take line level. if its Japanese bose, it will most likely take speaker level.
But how would I connect the factory speakers+amp to the soundcard? I can do it with the headunit but I have no headunit.
you need to tell us what signal level the bose amp is expecting-- we gave you the options-- if it takes line level, you only need to connect the pc directly to the amp, but if the bose amp needs speaker level, you will need to install a second amp to boost the signal to the bose amp. or you can remove the bose amp, and install a aftermarket amp.
I guess I am going to install an aftermarket amp that has rca input. So I guess I simply just plugged it into the amp rca from soundcard?
