Results 1 to 10 of 12
Thread: Wiring question
    Nov 2006
    Wiring question
    My battery died overnight again...this is rare and I am sure I have everything in my car setup so that its not drawing on the battery when the car isnt running really, but have one question...
    How much draw is on my battery when I have a setup like this, which i think is normal. From the battery I have a wire going to my power distribution block. Off the block is my 1F cap. Off the Cap is 2 amps. Obviously there is power from the battery that is traversing the distribution block, the cap and then to the amps. The amps only power on when the car is started (the remote portion of the amps).
    I'm wondering if having it setup like that is still causing a draw on the battery. If so, how should i have things wired?
    Jan 2008
    it sounds like the car audio setup is hooked up correctly, now, about the car computer-- how is it hooked up?
    Nov 2006
    Hanging off the distribution block is the Carnetix P2140. Which powers a SFF HP desktop installed under the passengers seat.
    I may be barking up the wrong tree here, it could be something else in my car, but this is the 2nd time its died in a week (optima red top).
    you can see the carnetix in the picture, on the left side near the amp for the subsm and the dist box right next to it.
    Jan 2008
    Would you be able to make a diagram with the way your system is connected? I have a hunch that it might be something to do with the capacitor, or the wiring to it
    Jan 2008
    Dartmouth, MA
    You can always check the exact load with a multimeter instead of guessing. How old is the battery?
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
    Nov 2006
    i have a RF cap that just has 2 terminals on it, postive and negative. i have the negative terminal going to ground. on the positive terminal is the wire coming from my power dis block as well as a wire from each of my amps.
    is this not right?
    Nov 2006
    btw, i got a new optima red top today. Autozone replaces them no questions for 3 years. so i have a new one, but dont want it to drain again lol
    Jan 2008
    Dartmouth, MA
    The cap is wired right.
    How many amp-hours does that battery have?
    Do you have a multimeter?
    Nov 2006
    i have this one, the second one down model 72-25
    http://www.autozone.com/autozone/cat...ive+and+Marine
    so again, i just got a new one of those and installed it just now.
    Nov 2006
    and yea i have a multimeter. pretty decent one with lots of options, i just use it for looking at volts.
  1. 04 Grand Prix Wiring question
    By djviper108 in forum Car Audio
    Last Post: 06-19-2007, 04:44 PM
  2. simple wiring question
    By yonu in forum Power Supplies
    Last Post: 01-19-2007, 05:00 PM
  3. Wiring question
    By pirate_king00 in forum General Hardware Discussion
    Last Post: 02-17-2005, 03:01 PM
  4. Wiring question
    By barometer in forum Newbie
    Last Post: 07-14-2004, 06:35 PM
