Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: 4x45 amp recommended, as small as possible
    Low Bitrate Hammerhand's Avatar
    Oct 2006
    Hello, I bought the hqct-ea solution for my wife carpc but it works horrible, I have to be restarting it many times and it doesn't work well with cf or windows neither, so I want to buy the hqct radio and put a 4x45 amplifier in the car.
    But I have been searching and I'm not sure of what to do: I don't want a too powerful amplifier (I will keep the factory speakers) but I don't want a too bad sound, and it have to be at least as small as hqct-ea (150x150x58). I wouldn't want that they were too much expensive.
    I have found in ebay some motorcycle amps as:
    http://cgi.ebay.es/4CH-41-WATT-CAR-M...d=p3286.c0.m14
    but I am not sure if they will sound well.
    Could anybody help me?
    What kind of amplifier should I buy?
    Thanks in advance.
    Jan 2008
    It looks like your on the right path! You should be able to find a couple different motorcycle amps to fit the bill. Most will be very similar in sound quality to the factory radio. Otherwise, if you are ok with building your own small amp, check out 41hz.com
    Jan 2009
    Oct 2006
    Quote Originally Posted by soundman98 View Post
    I have checked 41hz.com but it seems too difficult to me, I don't know how would I use it, so maybe the first option is better.
    I would agree with it if it souds like the factory radio or the hqct-ea (when it works lol), so if it is there, I will buy it as soon as possible!!
    Oct 2006
    Quote Originally Posted by summer69guy View Post
    ok I will check right now
    Oct 2006
    Quote Originally Posted by Hammerhand View Post
    Ok I've seen it right now but:
    maybe too powerful, wouldn't it hurt my speakers?
    I can't see how much it costs, the "buy it now" option doesn't work...
    Jan 2008
    I beleive they they might have some pre built options on 41hz, but haven't looked there for a while so i can't be sure. For the arc audio idea, arc makes some great amps, and I have not seen any horrible reports on any of their products-they seem very well built- the problem could be the cost for a well built amp--it won't be as cheap as most motorcycle amps
    Oct 2006
    Well I have been looking on 41hz but I can't see anything easy on their page, it seem more diy than I can do...
    the arc amp seems to be good but I can't see the prize throught their page or google.
    In fact, it seems to be "too good to be true", it will sure be very expensive...
    Jan 2008
    Last I looked, I believe the arc line starts at around $200
    edit: found a couple on google shopping- the ks series is close to the size as the motorcycle amp--the 125x4 version is Listed as $519...
    Oct 2006
    Wow it's toooooo expensive, I was thinking something nearer to 100$, but the motorcycle amps are about 50$ so my doubt is if they aren't too cheap...
  1. Need advice on small amp
    By agniusm in forum Car Audio
    Last Post: 08-21-2009, 09:09 AM
  2. Small 4 Channel Amp
    By TheMaskedMan in forum Car Audio
    Last Post: 06-28-2007, 07:48 PM
  3. Small rca amp
    By carpcguy in forum Car Audio
    Last Post: 07-17-2006, 04:59 PM
  4. Small AMP Board (AMP3 Alternatives)
    By bl3nd3r in forum Car Audio
    Last Post: 07-12-2006, 09:13 PM
  5. small amp for headphones
    By ren in forum General Hardware Discussion
    Last Post: 07-02-2004, 11:20 AM
