Results 1 to 5 of 5
Thread: 4 volt RCA's
    May 2009
    4 volt RCA's
    Hi,
    I've heard of some head units supporting 4 volt RCA's, What is the advantage of that?
    Thanks.
    Maximum Bitrate bratnetwork's Avatar
    Oct 2007
    Haledon, NJ
    Stronger clearer signal to your amps. More volume, less noise. Especially over a long wire run.
    May 2009
    Would it be noticable over normal RCA's on short runs, let's say 1.5m
    Jan 2008
    Yes- Overall, the higher the voltage of the preouts, the less chance that something will make the audio distorted- Eclipse is even rumored(I have only heard of them, not seen them) to have made some headunits with 18 volt preouts for competition use.
    Just need to make sure the amp can take it
    Variable Bitrate jessekilner's Avatar
    Aug 2008
    18v is rediculous.. why pay that much when you can take high ouput and plug it into the low level..yeah, yeah I know its not recommended.. but it will make that amp sweat when your volume is only on 1! 8v is more than enough in the industry.infact I beleive the 8V is intended to be split between multiple amps so theres enough juice in running to multiple amps... and to think my .2mV carpc on a JL Audio amp hurts my ears..lmao..
    Did it.. Done it... now I got to keep the neighbors kids away!!
  1. Regulated 12 volt to 5 volt conversion - Howto?
    By psyclobe in forum Power Supplies
    Last Post: 04-21-2010, 06:24 PM
  2. My Amp grounds through the Rca's anyway to fix?
    By Dragonlove in forum Car Audio
    Last Post: 08-19-2008, 09:06 AM
  3. Replies: 2
    Last Post: 05-31-2006, 03:58 PM
  4. CNX1900 .. 19 volt Xenarc screen
    By bluehcc in forum Power Supplies
    Last Post: 05-26-2005, 11:54 AM
  5. volt meter
    By Dragyn in forum General Hardware Discussion
    Last Post: 05-27-2001, 01:19 AM
