Results 11 to 20 of 22
Thread: 50 rms louder than 200rms?
  1. #11
    Nov 2009
    Quote Originally Posted by mrplix View Post
    It could realy be distortion, which makes the 50W amp sound loder. Are amp models the same?
    Yes, both are the same brand, Pioneer, but one of them is new and the other one is about 6-7 years old
    Also, can someone explain to me what 'distortion' exactly means?
  2. #12
    Low Bitrate Dexamenus's Avatar
    Nov 2008
    Quote Originally Posted by andruha1123 View Post
    new one sounds louder? no surprises there....
  3. #13
    Nov 2009
    Quote Originally Posted by Dexamenus View Post
    So, do you mean that 50 'new' rms should sound louder than 'old' 200rms?
  4. #14
    Nov 2008
    well from the info we have, anything could have happened to that sub over 7 years, degradation to the wires in the voice coil maybe, rust in the voice coil......
    I just dont think you can compare a 7 year old sub with a new one and expect them to sound like you do even with different power ratings
  5. #15
    Nov 2009
    I'm actually talking about amps, not the sub :P
    I just used the sub to test 2 amps
  6. #16
    Nov 2008
    woops, my bad, that'll teach me to skim read........i still say that degradation could be a factor.
    Hopefully some smarter people than me can help you out
  7. #17
    Low Bitrate pulsarsimon's Avatar
    Nov 2009
    Melbourne Australia
    6 or 7 years ago was before something called "CEA2006" power ratings. it was common for amplifiers to be rated higher than their actual output. if the older amp was 15 years old, it would likely be louder than the new one, for different but similar reasons.
    distortion, in technical terms, is the difference between the sound going into the amp, and the sound coming out. In simple terms, it's when you tun it up loud and the sound goes fuzzy or breaks up.
    MacMini in an Alfa? - Why not!
  8. #18
    Nov 2009
    Quote Originally Posted by pulsarsimon View Post
    6 or 7 years ago was before something called "CES2008" power ratings. it was common for amplifiers to be rated higher than their actual output. if the older amp was 15 years old, it would likely be louder than the new one, for different but similar reasons.
    Ok, that could be the reason.
    Also, the new amp has a HIGH LEVEL input and the older amp (200rms) is connected to the new(50rms) output. Could this be the reason?
  9. #19
    Nov 2009
    BTW, Thanks everyone for your input
  10. #20
    Variable Bitrate FPeter's Avatar
    May 2008
    Hungary
    i think the key is the input sensitivity! for example, You have a 2Vrms line output from the soundcard, the 50W amp has 2Vrms line input and the 200W amp has 4Vrms line input. the result is that You need 2x high gain level on 200W amp to reach the same loudness! but if You have a matching output, this amp will kick the other! of course the smaller one will be distorted because of too high output level...
    "case": Skoda Superb Elegance 1.8T
    Asrock G41MH-GE, E2180 2GHz dualcore, 1024MB DDR2/800, Samsung F1 750GB/7200RPM/32MB, M4-ATX, Lilliput FA1011 HDMI touchscreen, ASUS Xonar DG PCI, homemade Quectel L10 USB GPS
  1. More BMW Ibus command packets - The MID Buttons revealed
    By radiotrib in forum Software & Software Development
    Last Post: 08-07-2007, 02:26 AM
  2. WTB: 4x > 50 watt RMS amp
    By spazegun2213 in forum Classified Archive
    Last Post: 09-26-2005, 10:58 PM
  3. I need to some basic information about amps
    By Bust_A_Cap in forum Car Audio
    Last Post: 08-01-2004, 10:31 PM
Tags for this Thread
