Aha! Now I understand what you meant about the 4 channel. Thanks for the clarification. I was wondering about whether the volume would go up. Makes perfect sense now. So you're saying the volume would go up based on the resistance difference between the front and back speakers. So if the front and back speakers were all the same resistance, then twice as much wattage would go to the back speakers when I flip the switch. Is that the idea?
I see what you mean about the low level side of the amp. But I don't think I can do that with the mac mini without an external
sound card. Because it only outputs a stereo signal. If I flipped the switch on the low level side it would just cut the signal off completely to the amp. Wouldn't it?
