i would recomend setting the gain on the line amp to about 3 volts, and then using the gains on the amps to adjust for that(i think most amps have a marking for 2 volts-- so just above that). if it does not seem loud enough, re-adjust that amp gains. or, if you seem to have noise issues with the amp that need a louder source level, than up the gain on the lineamp, and lower the amp gains.
LinkBack URL
About LinkBacks
