Results 1 to 4 of 4
Thread: How to install a 4 channel amp to HU with only 2 Channel preamp
    Nov 2009
    I have a Kenwood KDC-MP232 which only have 2 RCA output, and a Formula-X FX-450 800W with 4 channel input and 2 channel ouput, and a Boss D10F sub-woofer. Don't really know are they all compatible or how to wire them up together. All helps is really appreciated.
    Jan 2008
    you should be able to hook up the amp using 2 rcas off the deck, but i cannot seem to find any specs on the amp, so i can't say what the best way to hook the amp and sub together would be. it is very possible that the amp is not 2 ohm stable, so hooking it incorrectly could damage the sub or amp.
    and just fyi: this is a car computer forum, so most answers will be heavily biased against non-computer controlled/integrated setups...
    check the sticky at the top of the car audio section for a listing of car audio forums.
    Newbie getonerd's Avatar
    Dec 2005
    Ohio
    u need rca y adapter ether 2 male to 1 female or 1 male to 2 female
    2005 Pontiac G6
    Headunit: AVH-P3100DVD
    Front speakers:Infinity 6022i
    Rear speakers: Powerbass pb-b6.5xv.2
    Battery: top of line walmart brand(LOL)
    Wiring: 1 run of 0 ga
    Amp: MTX JH600 & Lightning Audio B300.4
    Sub: TS-W2000SPL
    Jan 2008
    Quote Originally Posted by getonerd View Post
    not neccesarily-- from what i get from his vague post, it seems he only wants to power the sub, not any other speakers-- and depending on how he hooks it up, he will really only need 1 or 2 rcas-- 1 if he can bridg the channels for sub output, and 2 if he can run a stereo input.
    i was hoping he would repost with some more specs on the amp, or setup, but that doesn't seem to have happened...
  1. Amp into amp or just a new amp?
    By Profozone in forum Car Audio
    Last Post: 12-05-2009, 11:29 PM
  2. Sound card to speakers without HU or Amp.
    By spoonraker in forum General Hardware Discussion
    Last Post: 10-15-2006, 08:00 AM
  3. 5 channel amp + mono driving CENTER speakers?
    By vettejock99 in forum Car Audio
    Last Post: 01-19-2006, 11:51 AM
  4. Replies: 7
    Last Post: 12-20-2005, 11:08 AM
  5. 5 channel Amp suggestions
    By biglips31 in forum Car Audio
    Last Post: 11-05-2004, 04:30 PM
