Results 1 to 2 of 2
Thread: Independent Wiring Dual Voice Coil Sub to Mono Amp
    Dec 2009
    So I have a single Punch Stage 3 Rockford Fosgate subwoofer that is dual voice coil 4-ohm. I currently have it hooked up to a Sony mono amp wired in series for a load of 8-ohm. I would like for the amp to have a 4-ohm load, so I am thinking about running 4 independent wires to each terminal on the subwoofer. My amp has 4 terminals (2 positive, 2 Negative,) but is a mono amplifier. I am assuming that these terminals are all on the same channel, but are meant for hooking up 2 separate speakers. I am currently only running the sub from the left positive and negative terminals, with the right 2 doing nothing. If I run Independent wires from the amp to both voice coils, 1) Will my amp see a load of 4-ohm? 2) Will the subwoofer be safe because the signal is not coming from 2 different channels?
    Low Bitrate pulsarsimon's Avatar
    Nov 2009
    Melbourne Australia
    it will be 2 ohm, as the +'s are internally connected together, and the -'s are internally connected together. it will be the same as both the VC in parallel.
    only option for 4 ohm is 1x SVC 4 ohm, or DVC 2 ohm in series, or DVC 8 ohm in parallel.
    MacMini in an Alfa? - Why not!
  1. Amp into amp or just a new amp?
    By Profozone in forum Car Audio
    Last Post: 12-05-2009, 11:29 PM
  2. Did I hook up my Dual voice coil subs correctly?
    By Blackhawksfan24 in forum Car Audio
    Last Post: 06-11-2008, 10:15 AM
  3. Amp Wiring Kit
    By Pudge in forum Car Audio
    Last Post: 12-26-2006, 04:19 AM
  4. Using existing amp wiring for OPUS/Inverter?
    By SwapMeet in forum Power Supplies
    Last Post: 11-12-2004, 04:39 PM
  5. Recommendations for amp wiring kits...
    By hd54321 in forum Car Audio
    Last Post: 08-17-2004, 07:02 PM
