Results 1 to 6 of 6
Thread: Amp specs help!
    Nov 2009
    Amp specs help!
    Hi, I need to know rms on this amp:
    http://reviews.cnet.com/car-amplifie...-30234712.html
    Please help as soon as possible!!! Also, what would YOU pay for this amp...
    Maximum Bitrate bratnetwork's Avatar
    Oct 2007
    Haledon, NJ
    Upon a google search the specs for the amp seem to range quite a bit from seller to seller. The manufacturers website sucks. But to generalize from what I've seen is that RMS specs tend to be about half the max output. But this is definitely a lower end amp so the range might be even greater.
    What would I pay for it? I wouldn't pay anything for it. But if I was to I wouldn't pay more than $90 - $100 for it.
    Jan 2008
    Dartmouth, MA
    The fact that it doesn't list the RMS wattage shows that the amp doesn't come from a serious audio company and is a reason I wouldn't buy it.
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
    Nov 2009
    thanks guys! I know its a lower end amp and its about 7 years old, BUT i can buy this for 30 bucks!! Should i go for it?? (i want it to power 2 12 subs(only 250watts each)) Will it be good enough?
    Low Bitrate nalav's Avatar
    Apr 2009
    Louisiana
    Probably not. There's more to consider than simply watts. What subs are you trying to power? What is your price range for an amp? We might be able to point you in the right direction then.
    Jan 2008
    if you use some low end subs, it should be adequate. again, we would need the model number to check the specs to see how adequate it might be...
    $30 is a good deal if you are willing to accept that it might not be very good, and might not meet all of your expectations.
    i started of with a couple of low priced deals like that, and they will work good as long as you expect them not to be perfect, or meet all of your expectations, sadly it was just a stepping stone to a addiction to audio systems...
  1. Replies: 38
    Last Post: 11-30-2010, 06:04 AM
  2. Monsoon Amp bypassing
    By Esona in forum Car Audio
    Last Post: 08-14-2008, 11:40 PM
  3. YES!!! Yet Another Amp Problem
    By CaptainTrap in forum Car Audio
    Last Post: 03-24-2007, 10:58 PM
  4. Replies: 3
    Last Post: 12-07-2004, 07:34 PM
Tags for this Thread
