Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: Car PC lots of "noise", good USB attached sound?
  1. #21
    Jan 2008
    try dissconnecting the rca ground. or consider adding a preamp between the carputer and the amp if your gains are extremly high.
    long explanation:
    in my car, i had a issue that was very similar to what you described, i already tried a gli, and it did nothing-- stil alt. whine...
    i tried grounding everything, grounding the rca's acctually increased the noise.
    in the end, adding a preamp corrected it-- basically, i had my amp gains turned up all the way, which allowed the amp to pick up the noise. after i turned down the amp gains, i have not had any issues.
  2. #22
    Dec 2009
    im not using a GLI at the moment, the RCA's im using are very high quality, gold, home cinema cables, much thicker and better than the standard car audio stuff, and are run on the other side of the car away from and 12v sources.
    its worth noting that this noise is only present when the car pc is connected, when i connect an mp3 player in place of the car pc, there is no noise...
    i understand your pre amp suggestion, because if my amps are set on a lower setting the noise is almost non-existent (ie the voltage input switch) but the music is way to quiet. do you know of a good pre-amp?
  3. #23
    Jun 2008
    Seattle, WA
    David Navone makes some great quality line drivers.
  4. #24
    Jan 2008
    i did a review of the jl audio cl-rlc preamps/remote volume knob, and would highly recommend them, but i have also used pheonix gold preamps in a older cd player driven setup and had good luck with those as well.
  1. Replies: 334
    Last Post: 01-19-2011, 04:51 PM
  2. 2000 Mitsubishi Verada Car PC Install
    By MitchellO in forum Show off your project
    Last Post: 01-08-2010, 07:09 AM
  3. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
