Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Car PC lots of "noise", good USB attached sound?
    Dec 2009
    hi guys,
    new here, usually on fiatforum, but there ICE section just doesnt have the expertise.
    my problem:
    when i plug amplifier in via the 3.5mm jack on the motherboard, it generates TERRIBLE noise.....even with ground loop isolator (dont like using them anyway, they just "mask" the problem)
    so i bought a creative x-fi usb audio, this worked with a dramatic improvement reguaring noise. but it has lots of problems with windows and reusming form hibernate.
    anyone have any gems of wisdom to help me out here??
    thanks
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    One of the most popular sound boards I've seen used is the audigy.
    Want to:
    Dec 2009
    could youy elaborate a lil?
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    Have you merged the ground planes? Meaning, is the motherboard grounded to the vehicle chassis directly? In my experience this will help tremendously to mitigate a ground loop and other noise problems.
    Dec 2009
    no i havnt, when i tried this before, the motherboard sparked, smoked and died....whats the safest way to do it? as this sounds like the most logical step....
    Jan 2008
    Dartmouth, MA
    Also, try flipping the ground loop isolator in the other direction.
    How is your car's audio setup? Do you use a head unit? Do you have any amps?
    How is the computer powered? Are you using a power inverter? A dc-dc power supply?
    Is there an inverter in your car at all?
    Quote Originally Posted by mzhussein View Post
    How did you ground it last time?
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
    Dec 2009
    i dont think flipping the ground loop isolator will make a difference, due to its design, (its essentially 2 coils, side by side, so what ever way it is, it will be the same, unless its broken) also mine only connect one way.
    i go from car pc straight via 3.5mm jack, to delta box, then to 2 amps with 3 channels (front, rear, sub) thats how it is at the moment. no headunit.
    power comes from M1-atx/M2-atx (not sure, it came with a job lot of stuff i bought as an unfinished project, and is the of the only surviving original bits) supply, no inverters.
    last time when i tried to ground it (dont laugh) i wound a wire round one of the screws holding the motherboard down, so it was making contact with the little metal ring round the screw holes, then connected this to chassis.
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    That's an acceptable way to do it, although you should use a spade or ring connector to provide a safer connection.
    Then just connect the other end of the wire to a solid ground point on the chassis, even better would be the same point the power supply uses for ground.
    Just make sure to do everything with the computer off and the power supply disconnected from the battery.
    Dec 2009
    i did it with it on, because i was probing to see if it made better/worse, like at the opticians with lenses.....
    possibly not the best idea...
    Aze
    Aze is offline
    Dec 2005
    Roskilde, Denmark
    What motherboard are you using? is it with VIA chipset?
  1. Replies: 334
    Last Post: 01-19-2011, 03:51 PM
  2. 2000 Mitsubishi Verada Car PC Install
    By MitchellO in forum Show off your project
    Last Post: 01-08-2010, 06:09 AM
  3. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 11:19 AM
