Results 1 to 4 of 4
Thread: Wire speaker output to a hi-lo converter?
    Jan 2009
    I have a hi-lo converter with 5 wires:
    +/- Left
    +/- Right
    Ground
    The stereo has 4 wires
    12V+
    Ground
    Left+
    Right+
    How the hell do I wire those together?
    I tried twisting together both grounds together with the L/R- on the hi-lo together but that didn't work.
    Thanks,
    Kenny
    Jan 2008
    you might need to run new wire from all the speakers-- i know really old decks combine all of the speakers negative leads, but new decks cannot do this..
    Dec 2009
    Australia
    The deck has a common grounding, so you should be able to use that ground wire as if each speaker had its own negative.
    I'm not sure you need to do anything with the 12v line. Have you traced it? Where does it go? Is it used?
    Jan 2009
    I tapped the ground for the unit it was plugging into and that seems to have fixed it.
    Thanks guys
    -Kenny
  1. Speaker level input + RCA output?
    By prod in forum Car Audio
    Last Post: 12-10-2008, 04:32 AM
  2. Speaker wire to RCA cable to amp
    By klutes in forum Newbie
    Last Post: 08-16-2008, 09:07 PM
  3. Replies: 10
    Last Post: 08-12-2006, 10:12 PM
  4. RCA to Speaker wire?
    By greenglo in forum General Hardware Discussion
    Last Post: 02-16-2004, 02:20 PM
  5. PSU power over speaker wire???
    By Defiler in forum Power Supplies
    Last Post: 02-20-2003, 06:48 PM
